So do I buy a few protected 18500s and use 1 extension per light or use the stock 18350 and protected 18650 on one. Decisions, decisions
Buy AA Eneloops and give the triple to Granni?
endless possibilities… lol
Thanks for the info!
Does it get as low as the 2019 model? And if it is on high, does it step down once it heats up?
Oh, and can you figure out what the hole in the control ring is for?
Stock battery is a 700mAh 16340. IMHO protected 1200mAh 18350 is the best choice for this light since it’s already pretty long and shorter length seems like it would make being able to manipulate both the ring and tail switch easier. Can’t say that from experience since mine isn’t here till the 29th though.
The highest cap 18500s I’ve seen are only ~2000mAh or less, doesn’t seem worth it to me.
Good points about ring and switch. Shorter does seem better.
2200mAh is good but not protected. Guess it’s not necessary but nice for this light.
Stock battery on new one is an 18350 already according to site so that’s a nice upgrade from last year.
Oh nice, I missed that. Lists the turbo runtime as 35min vs 25 from the 2019 model so must be higher cap than 700mAh too.
If the extensions work for 2019 model - shouldn’t the 2019 head fit the 2020 tube then?
Yes. Just like the 2019 or 2012 version…. you can turn the control ring and get a gradual smooth dimming all the way until you can barely see the emitter is lit when staring directly into it from close range.
Appears to do nothing as far as I can tell. The RRT01 has the hole in the ring but the RRT03 does not.
Yes, the 2019 head fits and works with the 2020 body tube.
Protected 18350 are to long for the rrt-01 2019 version. Do they fit in 2020 version?
Thanks Firelight, means the weak spot of the 2019 model, its paper thin tube, can be fixed!
I don’t have any protected 18350, but they should have no trouble fitting.
The 18350 that the new 2020 RRT-01 and –03 comes with, includes a built-in USB port and charging circuit. It’s much longer than my Aspire 1100 mAh 18350 and is probably longer than any protected 18350 cell.
The overall light is pretty big for an 18350 light. Especially so for the RRT-01 which is slightly longer than the RRT-03 due to the longer reflector. In 18350 configuration the new RRT-01 is about the same size as an FW3A with 18650 tube.
Is there anywhere we can purchase the new 18650 extension tube?
Do AA cells rattle around in there or do they provide an adapter?
Nealsgadgets
My first-gen RRT01 will run on AA/NiMh voltage, however I don’t have any body tube that supports that size cell. Maybe one can be adapted from another Jetbeam light.
Firelight2
Can we ask for some pictures, please? I would like to see rrt03 and rrt01 optic.
I think you would need to buy the two extenders from one of the vendors, there is no actual 18650 tube
there is no Low Voltage Shutoff in the RRT-01 driver, and no thermal step down
a responsible user can manage unprotected cells, by observing when output gets dim, or starts to flicker, and/or by checking voltage manually. But if Granni falls asleep with the light on, it IS possible to overdischarge. So give Granni eneloops
It is also possible to damage an RRT-01 by tailstanding it on maximum, using LiIon. So, dont tailstand on maximum, as there is no thermal protection.
this is what my original 2012 RRT-01 does when voltage goes below 2.5v (by which time max output is less than 15 lumens):
I wonder who will be first to test the 2020 maximum output with AA Eneloop?
review says 18350 protected does work in the 2019 model…
(vinh also reported that protected 18350 works in the 2019 RRT-01):
Thank you for this valuable info! I had no idea that the RRT03 would lack infinitely variable control. Only 3 steps and the lowest isn’t moonlight? That’s a deal breaker for me. I can’t see what use there would be with this light, as it’s primarily a task light (RRT-01 has been that, due to infinite variable). Might as well get an Emisar D4SV2, as it implements the aux LED’s much better.
I meant that with protected 18350 2019 version cannot be assembled without small gap.
