Thank you for this valuable info! I had no idea that the RRT03 would lack infinitely variable control. Only 3 steps and the lowest isn’t moonlight? That’s a deal breaker for me. I can’t see what use there would be with this light, as it’s primarily a task light (RRT-01 has been that, due to infinite variable). Might as well get an Emisar D4SV2, as it implements the aux LED’s much better.
glad you are able to fit protected 18350 in your 2019 RRT-01, and that the gap is the same either way…
sounds like different copies of the 2019 RRT-01 have different size gaps with protected 18350…
it also sounds like the batteries themselves vary in length, as my 34.7mm vs your 35.2mm unprotected 18350 measurements are clearly different.
In any case, I think we all agree that the 2019 RRT-01 does work with Protected 18350, and does not expose the O ring, even though it does show the brass…
I asked Jetbeam about the hole in the control ring and they said this: “The control ring hole is for put grease into it. It’s not for tritium vial.” Can anyone explain what that means? They don’t need a hole on any other version of the light for the grease. Will this compromise waterproofing, or was that part of the design always on the outside of the waterproof barrier? Will this make it easier to regrease the ring down the road without diassembly?
The control ring has always been open to the elements. Over time they do get dry or gritty and needs cleaned and refreshed.
Grease tends to shed water so it helps a little being water resistant…
there is an O ring that seals the center of the control ring assembly, so even though water could get between the control ring contact faces (where the ball bearing rides), the water cannot get inside the pill.
here are some examples of the O ring seal on various models of magnetic rotaries
red O rings
black O ring on V10r Ti, which is similar to the 2019 and 2020 RRT-01 configuration (ignore the arrows, they are part of a past discussion of where to put grease)
plus locktite that seals the threads. (this is a V10r, also similar assembly as the 2019 and 2020 RRT-01
Do I need to email Neal about this or something? Looking at his website I can’t find just the extension tubes listed. I have 3 2019 light’s i’d love 18650 extension tubes for!
Received from Neal 2020 rrt01. The extension tubes came as part of the stock packaging so i think mainly available with the light??
Also pleasantly surprised by grey anodized. If i were a rocket scientist i could post a darn picture or two.
Also was sent xpl instead of nichia which made the decision whether to emitter swap for me.
Bezel opens to reveal mcpcb ready to extract and swap emitter. That sounds easier that opening older ones? I’m no expert though so don’t exactly know what I’m yakking about…ha ha, my phone put that word in for me… yakking
