I cannot find it in the store. Is it available?
KR1 W2 arrived today first impressions are good (except the clip). Performs a bit better than a decent C8 at a fraction of the size.
“Got” the KR1 with W1 and W2 today. Can pick it up in the post office tomorrow. Will try to make a few beamshots for comparison, but there’s a small issue with the sun. The nights are not as dark as during winter.
I’m looking forward to a W1 v. W2 comparison.
When can we expect the 16 LED mule Hank?
Got my KR1 W2 today and it's a.pretty nice light! Couple questions:
1. Is there any Anduril F/W for the KR1 anywhere yet? I looked here http://toykeeper.net/torches/fsm/ and don't see the KR1 listed.
2. Is the cheat sheet for Anduril the same as the one for my D4V2?
Now I just have to wait until dark to go outside and play with my KR1.
1. http://toykeeper.net/torches/fsm/anduril.2020-04-27.noctigon-k1.hex this is the latest, which you might have already. Do 15 clicks and read out the date in YYYYMMDD blinks or is it YYYYDDMM i forget
2. pretty much the same
Excellent and thanks! Didn't realize it was the same as the K1.
Well, just did 15 clicks numerous times because I keep getting a version that doesn't exist. I get 20200327 unless there is a mistake in the code that makes it flash out the incorrect month. I'm guessing it should be 20200427 since that one does exist and is the one you linked.
Oh opps I put the wrong link. I guess TK hasn’t made one for the KR1 but it’s probbly the same as the kr4.
I wouldn’t flash any firmware at the moment as long as we don’t know which firmware it runs. The KR1 does not use direct drive and I don’t know if this is limited by hardware or if the FET is disabled just by firmware.
My KR1 arrived in Germany last Friday. In my experience, it will now spent about 10 days at the customs . It is so much nicer to forget about an order and being surprised when something arrives .
Im interested in beam shots of any Osram emitter but the W2 is the one im after actually.
thanks lazerEagle
SammysHP
Noticed this after just 30 seconds on turbo (not more than 2-3 seconds at once with longer pauses in-between; only quickly for the beamshots) with the KR1 W2:
I hope Hank offers me a replacement head. This should not happen with a premium flashlight
Anyone who has a KR4 with 18350 tube—the standard pocket clip obviously does not work but can the lanyard ring still be installed with 18350 tube? It looks like the 18350 tube provides no space “in between” but it’s hard to tell.
No it does not work
Noticed this after just 30 seconds on turbo (not more than 2-3 seconds at once with longer pauses in-between; only quickly for the beamshots) with the KR1 W2: !https://i.imgur.com/NT2QkmS.jpg!:https://i.imgur.com/NT2QkmS.jpg I hope Hank offers me a replacement head. This should not happen with a premium flashlight
Dang, that sucks. I've had mine (W2 also) on turbo for probably a total of 2 or 3 minutes with 30-40 seconds at a time maximum and no such issue. So far, I love this light!
Hope Hank makes it right for you. Maybe it's a defective LED?
Didn't like the fact I couldn't use the lanyard ring and clip at the same time so I fixed it. I always (for the last few years) put a finger loop lanyard, first made of paracord or some other small cordage. Then CountyComm came out with their titanium beaded chain a couple years ago and it's all I've used on all my EDC lights since.
Always use a good cutting fluid and this stuff is the best (been using it for almost 20 years).
The bit I used.
Nice clean hole.
All done with a titanium CountyComm split ring.
