21700 D4K is available for pre-order
5695 posts / 0 new
Dougdimadome
Last seen: 1 year 9 months ago
When can we expect the 16 LED mule Hank?
srvctec
srvctec's picture
Last seen: 3 months 5 days ago
Got my KR1 W2 today and it's a.pretty nice light! Couple questions:
1.  Is there any Anduril F/W for the KR1 anywhere yet? I looked here http://toykeeper.net/torches/fsm/ and don't see the KR1 listed.
2.  Is the cheat sheet for Anduril the same as the one for my D4V2?
Now I just have to wait until dark to go outside and play with my KR1.
atobe
Last seen: 12 min 50 sec ago
srvctec wrote:
Got my KR1 W2 today and it’s a.pretty nice light! Couple questions:
1.  Is there any Anduril F/W for the KR1 anywhere yet? I looked here http://toykeeper.net/torches/fsm/ and don’t see the KR1 listed.
1. http://toykeeper.net/torches/fsm/anduril.2020-04-27.noctigon-k1.hex this is the latest, which you might have already. Do 15 clicks and read out the date in YYYYMMDD blinks or is it YYYYDDMM i forget
2. pretty much the same
srvctec
srvctec's picture
1. http://toykeeper.net/torches/fsm/anduril.2020-04-27.noctigon-k1.hex this is the latest, which you might have already. Do 15 clicks and read out the date in YYYYMMDD blinks or is it YYYYDDMM i forget 2. pretty much the same
Excellent and thanks!  Didn't realize it was the same as the K1.
Well, just did 15 clicks numerous times because I keep getting a version that doesn't exist.  I get 20200327 unless there is a mistake in the code that makes it flash out the incorrect month.  I'm guessing it should be 20200427 since that one does exist and is the one you linked.
atobe
Oh opps I put the wrong link. I guess TK hasn’t made one for the KR1 but it’s probbly the same as the kr4.
SammysHP
SammysHP's picture
Last seen: 1 hour 55 min ago
I wouldn’t flash any firmware at the moment as long as we don’t know which firmware it runs. The KR1 does not use direct drive and I don’t know if this is limited by hardware or if the FET is disabled just by firmware.
Unheard
Unheard's picture
Last seen: 27 min 41 sec ago
My KR1 arrived in Germany last Friday. In my experience, it will now spent about 10 days at the customs Tired . It is so much nicer to forget about an order and being surprised when something arrives Wink .
Spitzbube.
mortuus
mortuus's picture
Last seen: 1 day 2 hours ago
Im interested in beam shots of any Osram emitter but the W2 is the one im after actually.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
lazerEagle
lazerEagle's picture
Last seen: 7 hours 59 min ago
Some KR1 W2 Osram beamshots in this album Cool
- the best way to predict the future is to create it -
SammysHP
SammysHP's picture
I made some beamshots with W1 and W2 here: http://budgetlightforum.com/node/73337
mortuus
mortuus's picture
thanks lazerEagle SammysHP
              つ ◕_◕ ༽つ
SammysHP
SammysHP's picture
Noticed this after just 30 seconds on turbo (not more than 2-3 seconds at once with longer pauses in-between; only quickly for the beamshots) with the KR1 W2:
I hope Hank offers me a replacement head. This should not happen with a premium flashlight
mbp
Last seen: 2 months 3 days ago
Anyone who has a KR4 with 18350 tube—the standard pocket clip obviously does not work but can the lanyard ring still be installed with 18350 tube? It looks like the 18350 tube provides no space “in between” but it’s hard to tell.
shirnask
shirnask's picture
Last seen: 20 min 3 sec ago
No it does not work
srvctec
srvctec's picture
SammysHP wrote:
Noticed this after just 30 seconds on turbo (not more than 2-3 seconds at once with longer pauses in-between; only quickly for the beamshots) with the KR1 W2: !https://i.imgur.com/NT2QkmS.jpg!:https://i.imgur.com/NT2QkmS.jpg I hope Hank offers me a replacement head. This should not happen with a premium flashlight
Dang, that sucks.  I've had mine (W2 also) on turbo for probably a total of 2 or 3 minutes with 30-40 seconds at a time maximum and no such issue.  So far, I love this light!
Hope Hank makes it right for you.  Maybe it's a defective LED?
srvctec
srvctec's picture
Didn't like the fact I couldn't use the lanyard ring and clip at the same time so I fixed it.  I always (for the last few years) put a finger loop lanyard, first made of paracord or some other small cordage. Then CountyComm came out with their titanium beaded chain a couple years ago and it's all I've used on all my EDC lights since.
Always use a good cutting fluid and this stuff is the best (been using it for almost 20 years).
The bit I used.
Nice clean hole.
All done with a titanium CountyComm split ring.
will34
will34's picture
Last seen: 17 hours 41 min ago
How does the driver work on the KR1 with different emitter configurations, same driver just different programing? W1 limited to 5A, W2 to 7A and full FET for XPL HI and SST40?
dmsoule
Last seen: 2 days 13 hours ago
srvctec – great pics and description, thanks.
srvctec
srvctec's picture
dmsoule wrote:
srvctec - great pics and description, thanks.
You're welcome!  I can't even leave new stuff alone if it isn't the way I want it.
SammysHP
SammysHP's picture
I better don’t ask for the purpose of a titanium split ring. Big Smile
SammysHP
SammysHP's picture
Lol, wanted to have a closer look at the “spotted” LED in my KR1. There is one of these transparent o-rings between the head and the bezel. Yeah, these crappy ones that break easily. Mine got stretched pretty badly and it wasn’t easy to screw the bezel back on. Probably not water resistant anymore. Maybe it’s time to order a bigger set of o-rings…
There were some splatters of flux all over the MCPCB. And I found some tiny solder balls. Quality control could be better.
Btw, Hank offered me a replacement MCPCB. Thumbs Up I think I can live with that and for Hank it should be more cost efficient than everything else.
Unheard
Unheard's picture
Beauties:
D4V2, SST-20, 3000K, KR1, XP-L Hi 5D, 4000K
The color of the KR1 isn’t show correctly. It is a desaturated cyan, probably a color that cannot be pictured well digitally. Love it.
Spitzbube.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 year 1 month ago
I have read on another thread that Hank offered to custom-build a D4v2 with Luminus SST-20-DR (deep red, 660nm). I would be highly interested into something like that in a KR4 but I wonder how four of these LEDs will cope with any of Hank's drivers. I would prefer hardware-based current control instead of a custom-coded Andúril version.
mortuus
mortuus's picture
hows the surface on the KR light is it smooth or rough ?
              つ ◕_◕ ༽つ
SammysHP
SammysHP's picture
Neither. It’s a little bit rough, but very fine.
Hank Wang
Last seen: 4 days 6 hours ago
Lux-Perpetua wrote:
I have read on another thread that Hank offered to custom-build a D4v2 with Luminus SST-20-DR (deep red, 660nm). I would be highly interested into something like that in a KR4 but I wonder how four of these LEDs will cope with any of Hank’s drivers. I would prefer hardware-based current control instead of a custom-coded Andúril version.
Yes, we have customized this LED in the KR4, KR4 driver can be fully regulated without direct drive.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
lightdecay
Last seen: 1 year 11 months ago
That was me.
Hank built this flashlight for me a couple of weeks ago and I actually have it. It works well and it is fun to play with. It doesn’t even use a custom version of Anduril (AFAIK). SST-20-DR are rated to be driven at up to 3A, same as white SST-20. Obviously they will be overdriven in a D4V2, but it seems that they can handle it. I use 100% turbo a lot and it has not killed the LEDs yet.
I wouldn’t worry about it; if you want a custom KR4 with these emitters, just order one, it will work just fine.
Unheard
Unheard's picture
mortuus wrote:
hows the surface on the KR light […]
It’s nice Silly Wink
Spitzbube.
Lux-Perpetua
That's great. I will send you an e-mail right away to also get such a custom light. Love
Lux-Perpetua
lightdecay wrote:
That was me. Hank built this flashlight for me a couple of weeks ago and I actually have it. It works well and it is fun to play with. It doesn't even use a custom version of Anduril (AFAIK). SST-20-DR are rated to be driven at up to 3A, same as white SST-20. Obviously they will be overdriven in a D4V2, but it seems that they can handle it. I use 100% turbo a lot and it has not killed the LEDs yet. I wouldn't worry about it; if you want a custom KR4 with these emitters, just order one, it will work just fine.
Thanks a lot lightdecay! I will be happy to place my next order at Hank's shop. If only the long waiting to get this light could be skipped...
