Emisar D3AA is available now
Dang, that sucks. I've had mine (W2 also) on turbo for probably a total of 2 or 3 minutes with 30-40 seconds at a time maximum and no such issue. So far, I love this light!
Hope Hank makes it right for you. Maybe it's a defective LED?
Didn't like the fact I couldn't use the lanyard ring and clip at the same time so I fixed it. I always (for the last few years) put a finger loop lanyard, first made of paracord or some other small cordage. Then CountyComm came out with their titanium beaded chain a couple years ago and it's all I've used on all my EDC lights since.
Always use a good cutting fluid and this stuff is the best (been using it for almost 20 years).
The bit I used.
Nice clean hole.
All done with a titanium CountyComm split ring.
How does the driver work on the KR1 with different emitter configurations, same driver just different programing? W1 limited to 5A, W2 to 7A and full FET for XPL HI and SST40?
srvctec - great pics and description, thanks.
You're welcome! I can't even leave new stuff alone if it isn't the way I want it.
I better don’t ask for the purpose of a titanium split ring. :smiley:
Lol, wanted to have a closer look at the “spotted” LED in my KR1. There is one of these transparent o-rings between the head and the bezel. Yeah, these crappy ones that break easily. Mine got stretched pretty badly and it wasn’t easy to screw the bezel back on. Probably not water resistant anymore. Maybe it’s time to order a bigger set of o-rings…
There were some splatters of flux all over the MCPCB. And I found some tiny solder balls. Quality control could be better.
Btw, Hank offered me a replacement MCPCB. :+1: I think I can live with that and for Hank it should be more cost efficient than everything else.
Beauties:
D4V2, SST-20, 3000K, KR1, XP-L Hi 5D, 4000K
The color of the KR1 isn’t show correctly. It is a desaturated cyan, probably a color that cannot be pictured well digitally. Love it.
I have read on another thread that Hank offered to custom-build a D4v2 with Luminus SST-20-DR (deep red, 660nm). I would be highly interested into something like that in a KR4 but I wonder how four of these LEDs will cope with any of Hank's drivers. I would prefer hardware-based current control instead of a custom-coded Andúril version.
hows the surface on the KR light is it smooth or rough ?
Neither. It’s a little bit rough, but very fine.
Yes, we have customized this LED in the KR4, KR4 driver can be fully regulated without direct drive.
That was me.
Hank built this flashlight for me a couple of weeks ago and I actually have it. It works well and it is fun to play with. It doesn’t even use a custom version of Anduril (AFAIK). SST-20-DR are rated to be driven at up to 3A, same as white SST-20. Obviously they will be overdriven in a D4V2, but it seems that they can handle it. I use 100% turbo a lot and it has not killed the LEDs yet.
I wouldn’t worry about it; if you want a custom KR4 with these emitters, just order one, it will work just fine.
It’s nice :stuck_out_tongue: :wink:
That's great. I will send you an e-mail right away to also get such a custom light. :LOVE:
Thanks a lot lightdecay! I will be happy to place my next order at Hank's shop. If only the long waiting to get this light could be skipped...
Ask Hank if he can ship to your location with DHL. It could be a lot faster.
Thanks to you guys I just placed another order via e-mail for this custom KR4 with SST-20 Deep Red (660nm) and another KR1 with W2.
Hank already replied - wow, that's fast. These new lights will greatly fit into my Emisar collection. :-)
If I recall correctly, all my orders from Hank came delivered by DHL anyway. However, fast shipping is always a good thing.
It's nice! Hope this helps. There are some really fine grooves machined in the body.
I made a quick video comparing beamshots of the W1 KR1 with the BLF A6, Emisar D1 (SST40 5000k), Emisar D1s (6500k) and Astrolux FT03 (XHP 50.2 5700k)
