Scallywag
(Scallywag)
June 19, 2020, 2:36pm
36
I wonder where the BLF Q8 lands for sustained output (and then, modded with 50.2s, what it can sustain)? Or lights like Convoy L6/Sofirn SP70
I know for sure that my convoy L6 can stay on turbo indefinitely, it doesn’t get that warm….
icpart
(icpart)
June 19, 2020, 4:59pm
38
mizou51:
What a strange race we are facing in 2019/2020….the more lumens possible in a lowest possible time ?
It started with imalent flashlights 3 years ago…
i would like to see a small light that can sustain 3000lm for 10min.
For that reason I decide to order SST40 variant of Nightwatch with 5k lumens because want turbo for longer times and its have better heat dissipation design compared to FW21Pro.
DHart
(DHart)
June 29, 2020, 6:25am
39
I have a stock FW21 Pro. Does anyone know what the color temp is with the XHP50.2 emitters in this? 5000k? Or 6500k?
The color temp is ok for me, but my only quibble with the XHP50.2 is the green corona around the hotspot is a little irksome, though it isn’t terribly bothersome - generally only noticeable when white wall hunting. But I do appreciate minor improvements, when I can get them.
Is there another emitter option, to mod this light with, to get rid of the green corona, but still retain reasonably high, cool white, lumen levels? Would XP-L emitters work well in place of the XHP50.2 emitters?
I don’t care if I can’t hit 10,000 lumens on turbo. For the most part, I would use the light within the ramp range, only using turbo very briefly on occasion.
icpart
(icpart)
June 29, 2020, 12:57pm
40
Probably 6500K is original FW21Pro emitters. 5000K version of XHP50.2 are difficult to find and manufactured only by special order. Good replacement for XHP50.2 is SST40.
mortuus
(mortuus)
June 29, 2020, 7:11am
41
why not XHP70.2 ? they exist in neutral and warm white tints…
DHart
(DHart)
June 29, 2020, 7:33am
42
I’ve read that the SST40 has a greenish tint shift at med to low levels?
DHart
(DHart)
June 29, 2020, 7:34am
43
Good question! Do these have a greenish corona around the central beam, as the XHP50.2 does?
If not, I’m sure I’d be thrilled with moving to XHP70.2 in neutral tint.
mortuus
(mortuus)
June 29, 2020, 7:42am
44
DHart:
No idea, i dont own any light with that emitter sadly… but i just placed order for the FW21 from neals… need this light haha
ch1ir
(ch1ir)
June 29, 2020, 2:44pm
45
What is the best battery for this light (NightwatchNSX3) for Max output? Samsung 30t? 40t? Button top, flat top, both?
I have a sofirn 21700 40a
and an ijoy 20700 40a
I don’t know if they are enough to do the job. Thanks for the input!
ch1ir:
Max output bar none: Samsung 30T
Best all around 21700: Molicel P42a and/or Samsung 40T
I have 2 molicells and 2 40Ts.
I’ll see if I can do a full charge output test
I don’t think the type of top matters unless you arent getting contact…
ch1ir
(ch1ir)
June 29, 2020, 3:37pm
47
Rockenrooster:
ch1ir:
do you have a suggestion on where to buy in the states
Flat top.
Imrbatteries.com is where I bought mine.
ch1ir
(ch1ir)
June 29, 2020, 3:50pm
49
Thank you!
Is there any harm is trying the ijoy or the sofirn? They are both rated at 40 max amps
Link to ijoy I have
I appreciate your help!
No harm, you might not even be able to “see” the difference.
DHart
(DHart)
June 29, 2020, 6:15pm
51
40 amps is plenty - IF you can trust the rating.
ch1ir
(ch1ir)
June 29, 2020, 4:28pm
52
I just didn’t know if there was any chance of harming the battery or light I’m still noob
This is incorrect. Those are fake rating and usually top out at 15 amps or so
ch1ir
(ch1ir)
June 29, 2020, 5:00pm
54
Well damn, I guess it Samsung 40T time
mortuus
(mortuus)
June 29, 2020, 5:19pm
55
40T is the best battery if u want decent runtimes and plenty of amps to run this kind of lights.
