For that reason I decide to order SST40 variant of Nightwatch with 5k lumens because want turbo for longer times and its have better heat dissipation design compared to FW21Pro.
I have a stock FW21 Pro. Does anyone know what the color temp is with the XHP50.2 emitters in this? 5000k? Or 6500k?
The color temp is ok for me, but my only quibble with the XHP50.2 is the green corona around the hotspot is a little irksome, though it isn’t terribly bothersome - generally only noticeable when white wall hunting. But I do appreciate minor improvements, when I can get them.
Is there another emitter option, to mod this light with, to get rid of the green corona, but still retain reasonably high, cool white, lumen levels? Would XP-L emitters work well in place of the XHP50.2 emitters?
I don’t care if I can’t hit 10,000 lumens on turbo. For the most part, I would use the light within the ramp range, only using turbo very briefly on occasion.
Probably 6500K is original FW21Pro emitters. 5000K version of XHP50.2 are difficult to find and manufactured only by special order. Good replacement for XHP50.2 is SST40.
Ok I just tested my fully charged 40T against one of my Molicell P42a in my FW21 Pro (turbo of course).
My homemade lux meter box results (highest @ turn on using):
P42a: ~16,600 lux
40T: ~13,800 lux
(Note that these results are relative to me only)
I am not able to detect a visual difference in regular usage (dark room or outside), but the difference is measurable with a meter.
I’ve decided to reserve my Molicells for my FW21 Pro and use the 40Ts when I get my E07.
