LOL. Maybe if you can get them rotating fast enough. Mine are coming Fri also. They sound like a good buy. I wish I could get more than one per Amazon account. They would make good stocking stuffers.
A different approach to mowing and noise cancelation for sure. I’m working on a breakthrough jello hammer invention, just need startup funding from some forward looking venture capitalists. :money_mouth_face:
Saw the H12's with Vipon $13 off comes out to $10.50 The H16's going for $15 with Amazon clip coupon.
Also saw the H20's in Amazon at $39.99 with amazon clip $20 off, total $20. Mind you I just bought the H10's and have no idea about the difference between those and the H18's.
I received the H12s today— they are very similiar to the H10 —- They look a little more refined—blacked out
They could very well be the same headphones with a different look
I didn’t realize the ANC worked even if the headphones weren’t on
Aha. Thought it was a combo of bt and internal amp.
Forgot how my [Bose] QC15s worked (got killed by an alkaleak). Wired-only, no bt, but iirr they needed to be turned on for the internal amp to work. Ie, don’t recall if they worked “passively” with no power. Probably did, but ain’t sure.
I can’t see on the pictures if the MPOW headphones have a 3.5mm jack and come with a replaceble audio cable (3.5mm on both sides) or the audio cable is permanently attached?
