Hi all, is MPOW H18 for $20 a good deal??
thanks
^ Good question.
Whoa… where ya see that?
I paid 30, and like ’em, so 20 would be an even better deal.
Looked, H12s 10bux off, with a vipon brings ’em down to like 14 or so.
Fire-sale at mpow??
Saw the H12's with Vipon $13 off comes out to $10.50 The H16's going for $15 with Amazon clip coupon.
Also saw the H20's in Amazon at $39.99 with amazon clip $20 off, total $20. Mind you I just bought the H10's and have no idea about the difference between those and the H18's.
I received the H12s today— they are very similiar to the H10 —- They look a little more refined—blacked out
They could very well be the same headphones with a different look
I didn’t realize the ANC worked even if the headphones weren’t on
saw that deal on amazon . 39.99 - 20 off coupon.
I wonder when MPOW runs out of numbers — will they change the fore letter (H) — Man they have a lot of models
Sumbitch… I’ve been forgetting to “turn ’em on” but just kicking in the ANC. :person_facepalming:
Sounded pretty good, regardless. :laughing:
Yup—when the wife starts —just click on the ANC—Or maybe we can rename it WNC
The power is for bluetooth functionality, if you’re just using it wired, there is no need to turn on anything other than ANC.
KuoH
Aha. Thought it was a combo of bt and internal amp.
Forgot how my [Bose] QC15s worked (got killed by an alkaleak). Wired-only, no bt, but iirr they needed to be turned on for the internal amp to work. Ie, don’t recall if they worked “passively” with no power. Probably did, but ain’t sure.
I can’t see on the pictures if the MPOW headphones have a 3.5mm jack and come with a replaceble audio cable (3.5mm on both sides) or the audio cable is permanently attached?
You might have to read Amazon reviews for the first two questions.
For the last question, if the headphones have bluetooth, the audio cable is not permanently attached.
got it thanks
Which Mpow model are you referring to?
All. I’m using the cable from my B3s.
For $10 hope it works for music when mowing the lawn.
Will give it a whirl, compare with some of my other headphones, possibly test on my several headphone amps.
Thanks for posting the deal.
i found good coupon. that is not flashlight or tech stuff, but discount is good
Nakey Memory Foam Pillow, Orthopedic Contour Ergonomic Bed Pillow with Double Cores
coupon code 34YU6EKC was $69.99 coupon price $39.89
valid until 31 july
Music headphones with active noise cancellation won’t eliminate the lawnmower sound (won’t protect your hearing one bit); it might just mask it so it isn’t as irritating. I use regular earmuffs to block the noise when I mow. But then, I already have some hearing loss. (Probably from certain forum members yelling at me from halfway across the globe .)
