Usually protected batteries also have buttons, but not always. The protection circuit is usually on the negative side of the battery. You can have a protection circuit and not have a button. You can also have a button without protection. It is easy to hide the wire running from the anode to the cathode with a button, so usually a button is added. Bottom line…the existence, nor lack of the existence of a button does not indicate protection, or lack of protection.
All of that considered… I’m betting Sofirn wasn’t asking me to add protected buttons. I also don’t think the light can hit 7k lumens with any protection. I guess we’ll see
6 one way 1/2 a dozen the other… I’ve had some Sofirn store stuff come in three weeks and other stuff come in two months. WHEN I was buying from the Sofirn AliExpress store, everything took 5-7 weeks and today… other ALiExpress sellers are also taking about that same time using China post (usually).
If I wanted it fast lately, I asked for an Amazon code from Barry/Lan Lee at the Sofirn.com store and pricing was pretty close using the codes. But lately, Amazon isn’t stocking some of Sofirn’s items like they were last month? Like the LT1: I had a code for it I was going to use, but waited too long and it’s stocked out today with “no known stock on the way.”
One thing I will say though is ALL orders have eventually come in (about 6 total this year) and one came yesterday that I ordered on Match 17th. But the seller (I bought from before) kept in touch and worked with me until it got here.
My strategy is… I just plan for what I need 4 months out. And I have one more (out of four) LT1s on the way here in a few weeks (maybe?) for my September fishing trip that starts my 6 months of hunting/fishing. I AM looking forward to not pumping up my Coleman lanterns for the first time since I bought them back in the 80s.
Origin - Cached time: 2020-07-01 12:17:04 (GMT+00:00)
2020-06-30 15:04
纽约, 到达寄达地处理中心
2020-05-21 22:40
上海市, 已交航空公司运输
2020-05-19 07:54
上海市, 离开【国际邮件处理中心】,下一站【上海国际邮件交换站】(经转)
2020-05-19 04:35
SHANGHAI,CHINA, Processed Through Facility
2020-05-19 04:35
上海市, 【国际邮件处理中心】已出口直封
2020-05-19 03:04
2020-05-18 19:00
上海市, 到达【国际邮件处理中心】(经转)
2020-05-18 17:19
上海市, 离开【邮政广商局国际小包业务收寄点】,下一站【上海国际】
2020-05-18 15:30
上海市, 【邮政广商局国际小包业务收寄点】已收件,揽投员:p杨新龙
2020-05-17 16:32
Last mile=> Destination country post, number RV432058317CN
2020-05-17 14:32
Departed from Yanwen Facility
2020-05-16 11:33
Process completed in Yanwen Facility
2020-05-15 21:49
I think there are a lot of flashlights stuck in Jamaica, NY.
If Sofirn hit the 7000 lumen mark by removing the protection circuit, they need not have bothered for me. If there is not a protection circuit built into the light, I will not use unprotected batteries in a single battery light. I would have to seriously question the sanity of someone who does so with stacked batteries. Even if the light has protections built in on a stacked battery configuration, it can only do so by treating the stacked batteries as if it were 1 large 7.4 volt battery, instead of 2 x 3.7 volt batteries. That is not ideal for a lithium ion battery. As a long time user of lithium ion batteries in vape devices I might have watched too many videos demonstrating a thermal runaway of a lithium ion battery, but I care much more about the safety of these batteries than I do about an added 1500 lumens. I will not even use the cheap re-wrapped batteries that ship with some cheap lights that lie about the mah ratings and current ratings of their batteries. The added cost of high quality protected batteries is a small price to pay for the added peace of mind it provides. Consider this, almost everyone has had alkaline batteries rupture if left in a device that is unused for an extended period. If the same happens with a lithium ion battery, it can result in a fire as opposed to battery acid just ruining the device. I love the added power and run time made possible with lithium ion batteries, but I have a healthy respect for the added danger of using these batteries. Unfortunately, too many businesses print elevated claims on battery wraps, and too many consumers assume that these companies would not be selling unsafe batteries. Battery safety is essential for lithium ion batteries in my opinion. I cringe when I see people using these batteries with torn wraps. These wraps are dirt cheap, and are easily replaced using the wrap and a hair dryer. I urge everyone to watch a youtube video of a lithium ion battery thermal runaway just to be aware of the danger here.
As a follow up, I received the sp70 with the button top batteries today. They are indeed unprotected cells. Having another identical sp70, I compared the 2 lights on turbo. One had 5500 mah orbtronic protected cells. The other had the supplied unprotected cells. I shined them both on turbo against various surfaces, and could not see any discernible difference between the 2 lights. It makes no sense to me why series connected batteries would ever not be able to supply the needed current while fully charged. It might not be able to do so once the voltage drops below 3.7 volts, so perhaps there might be more lumens in the latter stages of discharge cycle. It certainly makes no sense at all to give up the added safety the protected cell provides, especially in a stacked cell configuration. The big issue with stacked cells on unprotected batteries comes into play when one battery degrades. That in turn can increase the discharge rate on the good battery to exceed the safe discharge rate. The protection circuit would prevent a dangerous over current by disconnecting the battery until it cools. In unprotected lights it might result in the light cutting off a few minutes after running a while on high. It will happen more frequently as the voltage drops in the charge cycle. The light will have increased amperage to maintain the current needed. If unprotected the light can be discharged below the recommended minimum voltage which can ruin the battery or even cause it to vent. In theory, you can use unprotected cells in single cell lights if great care is used to maintain adequate voltage. That can cause the light to dim, and that is a sure sign that it needs re-charging before continuing use. A single cell light can, and many do, build the protection into the light itself, eliminating the need for protected cells. I will use these cells provided in a single cell light with the built in protection. The Orbtronic protected cells will be used in this light. I am not willing to sacrifice the added safety of the protected cells, for the slight, if any, gain in lumens near the end of the discharge cycle. Having been an electro-mechanical engineer at a tire manufacturer has provided me with the training to know better. It is just not worth the risk involved…period.
Did you charge the newly received cells before testing? In my experience cells typically arrive charged to around 3.6v
Of course I fully charged both sets of batteries used…always. I have no idea how low the charge in newly received batteries ever are, because as soon as they drop to room temperature they go on the charger…an xtar dragon vp4 plus.
It was for me…ordered a sp70 from Sofirn, and two weeks later ordered from aliexpress, and received the aliexpress order 4 days before the Sofirn order. Banggood however has been fairly close to the same as Sofirn on items not already in the USA.
just recieved LT1 with batteries and case ordered 5/16 arrived 7/1. Washington State, USA - direct from Sofirn.
Cheers to Barry at Sofirnlight.com! I ordered the SP70 Kit with HD 26650 batteries and charger and I received exactly as ordered, pictured below. I placed my order June 18 and received perfectly at my door via USPS on July 2. Really excellent turnaround/ delivery time for something coming from overseas. Thank you Barry at Sofirn!
On the two week statement, we will have to agree to disagree. My orders are taking about a month or longer, and the tracking is not working well either. Like Sofirn lights, but shipping is lacking.
I agree the former shipping to USA takes really looong. But please know that we use new shipping service for orders to USA since June 20th.
What is my flashlight order doing…order date May 31, I live in South Carolina. Was scanned at JFK, New York on June 15, went 2000 miles further away to be scanned in Bloomington CA on JUN 26. It then was scanned in Atlanta Georgia on July 10…and I am thinking it is getting close now. Imagine my shock, when tracking showed it arriving back in Bloomington CA on July 11. So it went from NY to California to Atlanta where it was sent back to California, can anyone explain a possible reason for this order to go from the East Coast, to the West Coast, back nearly to the East Coast, back to the same City it had once visited on the West Coast again. Who runs these shipping companies?
Check your tracking info for Pitney Bowes. They have some really lousy routing. For my package 16 days from Jamaica, NY to Greenwood IN. It departed Greenwood, IN two days ago headed who knows where.
This was an order from May 12th sofirnlight sat on with no notification of a problem. After waiting a month for shipping notification I inquired via email and was told one of the items was out of stock though the website showed it in stock. I was given the options of cancelling the item or waiting another month for restocking. I cancelled that item. If there’s a problem at the very least contact the buyer and inform them that there’s a problem.
17TRACK
In transit
China
YANWEN
United States
2020-07-12 11:59Your item departed a shipping partner facility at 11:59 am on July 12, 2020 in GREENWOOD, IN 46143. This does not indicate receipt by the USPS or the actual mailing date.
Destination
Origin - Tracking consuming: 144 ms
2020-07-12 11:59
2020-07-09 00:06
Arrived Shipping Partner Facility, USPS Awaiting Item, July 9, 2020, 12:06 am, GREENWOOD, IN 46143
2020-07-09 00:06
Your item arrived at a shipping partner facility at 12:06 am on July 9, 2020 in GREENWOOD, IN 46143. This does not indicate receipt by the USPS or the actual mailing date.
2020-06-24 08:32
Your item was picked up by a shipping partner at 8:32 am on June 24, 2020 in JAMAICA, NY 11434. This does not indicate receipt by the USPS or the actual mailing date.
2020-06-24 07:32
Jamaica, Electronic Shipping Info Received
2020-06-20 05:06
LAX-LOS ANGELES, Arrive at destination airport
2020-06-14 08:26
Last mile=> Destination country post, number 4204412592612927005303010008947477
2020-06-14 06:26
2020-06-13 02:29
2020-06-12 15:54
Picked up
After 6 weeks of bouncing back and forth between the East and West coast this order finally bounced into my mailbox….still I am mighty curious as to why it went to Atlanta from California, just to turn around and go back to California. I will likely never know the answer to this strange odyssey.
Maybe it just wanted to run. But after helping a guy in the bumper sticker business and another guy in the t-shirt business, it got pretty tired, and went home.
