WTB: Jetbeam RRT01 – Any place to buy it?! + [RRT01 2019 discussion]
Dang it, i wrote a reply and lost it.
Will check with you later after i photo the light by itself at night.
What is changed between the three shots?
Mine do look less ringy but we'll compare.
I think the marketing strategy in addition to lumens driven, is throw driven. They don't care about the quality of light (well, throw pwr does have its place) but the numbers that can be written down.
My smooth reflectors (3+) seem to share this effect. The "worst" being the throwy d1 with a cree. So add tint shift to that, which this has little to none.
Jc
Does the Nichia die lie deeper than the XP-L die? I have a non-perfect beam with the D25A (XP-L HD to 219B) and wonder what I can do. Same in a BLF A6 where thinning the gasket and finally slicing the LED didn’t work out (eventually I replaced the reflector by a honeycomb optics to save the light and now using it as fill light). TIR optics would be ok for the Eagtac also if I can find one, but it would be great to keep the OPR. Sorry for OT, but I hope it fits in this discussion.
It probably does sit too high on mine but the reflector has a lip on it so it sits on the body of the light so sanding the spacer may not be enough unless you raise pcb too.
I do not use the imgur app on my phone
If I use my phone, I dont have access to posting images, only to creating “posts” that the horny idiots go crazy commenting about
this way I dont get any comments from the peanut gallery, note the choice for Images instead of Post
and yes, it is more complicated than reflowing an LED… I take photo w phone, then email to my desktop, then load to imgur, then open in Preview and add text labels, then post to BLF… but photos still save me a TON of typing
imo the problem is not the height. I think the beam shadow is caused by the larger opening at the base of the reflector
but to be fair, until we see the XP-L beam in a photo I reserve judgement whether the 219b is worse, or the reflector sucks for both
here is a comparison of an xml and xpg reflector in a sunwayman V10r Ti and V10r Ti+
here is an example of a stock xm-l2 and xpg beam in the sunwaymen…
xml2 has the shadow in the spill, even in stock form… The xpg is much nicer… (both beams retain the traits after modding to 219b)
the mod to the 2012 RRT-01 involves swapping in a reflector with a smaller hole at the bottom, which imo is key to beam success with that model
some examples of beam quality after modding, left is better (small hole reflector), right is worse
note that the xml reflector beam is has a shadow ring in the spill in both stock and modded form. People who are not whitewall hunters would never notice.
So, if I do a mod to a reflector with a wide hole at the bottom, I dont beat myself up when the beam is no better than stock… it is still worth the High CRI upgrade, and for many applications I mainly use the hotspot, which is fine…
another view of large hole and small hole reflectors
modded vs stock (small hole reflector)
stock vs modded (large hole reflector)
I’ve seen worser artifacts in a beam than in the beam of my D25A, e.g. those of various Armyteks. Was never a problem since this was a property of the respective stock light. But when I modify a light and there’s something even barely wrong, it’s a drama. Maybe I’ll try a LH351D or a nice XP-L HD. The 219B always works in small lights like the Drop tools, and yes, the opening on those is very small. Just fits a Samsung. Very tight fit.
Thanks for the pictures, Jon!
same here :slight_smile:
I get really nitpicky once I start modding
its the same when I take my car to a mechanic… even if it only needs an oil change, when I get it back Im secretely hoping it has a new motor, more power, and better fuel economy too… LOL
Ive spent a fortune on oil changes, and my car keeps getting older… I still dont understand, so Im taking it in for another oil change soon :slight_smile:
What’s the Low Voltage Warning like for the RRT01 Raptor?
Does it flash at 2.5V?
officially there is no LVP and no LVW, so you should use protected cells, or if you choose to use unprotected, do so responsibly, and check battery voltage periodically.
if you, or anyone else here, tests any model of RRT-01, please share what you learn
Im guessing they all flash at 2.5v, like my 2012 RRT-01 does:
I seek confirmation for your model
I recommend recharging LiIon cells before they drop below 3.2v, the LVW at 2.5v that I posted should not be relied upon as a recharging indicator…
I ordered an RRT01 Raptor from Neal on 18th June. Unfulfilled.
Asked via FB on 28th June. No reply.
Asked again today, 6th July, in Chinese. Immediate reply :slight_smile:
He’s waiting a few more days for a shipment from JETBeam. He paid them half a month ago.
Neal takes a while to respond sometimes but all the sudden you’ll get a tracking notice when it’s shipped. I got mine shipped june11 which was probably the first batch he got, the others prob went to vendors , i only got in because i had ordered a 2019 right before he listed as discontinued. Took a little over 2 weeks after shipping… quick for Corona standards…
Sit tight!
Found my stock xplhi beamshots before the 219b went in!
Btw my reylight cooper mini clicky 219b seems whiter than my sw45ks. Can someone tell me is this a thing or are my batch a warmer batch? I have a fireflies also is similar white rosy, so with 7 emitters, can't be a fluke?? Anyone know if those run cool? Were they cherry picked for that or maybe my small strip of sw45k run warm? Feedback? So, back to topic, the referred to reylight is pictured below on the right. 2020rrt01 w stock xplhi on left
Maybe i got lucky but i remember the beam being this un-ringy, hence the swap pretty good in that regard...
Stock 2020rrt01 vs swapped to sw40 fenix e20v2 shot indoors at workduring the day.
Here's a pic of the reflector, I'll take better pic when i get in there again to clean some stuff up. i would call it the big opening type with a snug fit up ring.
Here's two stand alone of my 2020 rrt01 after sw45k to compare with contractor's 2019s. (Both pretty low setting, maybe 30%.) When brighter, even less rings. There is a sweet spot i can dial in where i can see some rings from the centering ring to reflector boundary but they don't show up possibly because of my crude photographic method! Im trying! When i messed with white balance, things went south...
Contactor, were your 3 shots 3 different lights or different shots of the same light?
Im thinking the 2020 got new reflector/ other tidbits plus i got lucky.
PS. With this light, everything for swap was accessible from the bezel end... no coming up from underneath, is 2019 / earlier like that? Definitely no fitment issues on reassembly, except for needing to smush down my blobby solders. And pps. The centering ring such a tight fit, i had to remove reflow solder squeezeout for proper seating of the reflector assembly.
Jc
Thx for comparisson photoset.
I wouldn’t bother with the 2019/20 reflector cause it gives perfect beam unlike 2012 even after upgrade.
What i did on one of my 2019 was that i’ve installed Yaijamei TIR instead. Beam vecame just a round hotspot without the spill. And in combination with swapped 351D 5000K instead of XPL-HI is awesome.
thanks for tip about that tir. my main complaint was that i didnt want a thrower or at least such a hot hot and weak spill. i also did not want to resort to dcfix or frosted lenses. but considered pebbled lens. i will likeley try that tir first, did it fit up well? have you looked at that fancy finnish reflector on darksucks site? wondered if that fit, but maybe its too similar to what we are already getting stock.
also, its a pretty mild AR if at all? did you add better AR lens?
I thought I saw this post somewhere but remind me what other changes you had to make. Did you have to get different o-ring or glass? I cant recall
Don't have this sucker with me now but if i'm not mistaken TIR is a tad narrower than reflector opening so you have to be careful when assembling bezel ring.
Lens fits snugly but it fits. Realy nice option to a reflector and i like big hotspot without any spill so i'd highly recommend.
It reminds me of Surefire Fresnel and Olight M2R Pro beams.
I tried a handful of TIRs with a 219B and they were just OK. I didn’t go above 15 degree TIR though. Half the ones I had did not fit at all. It seems the only ones that fit had the very small “lip” on the LED opening. The wide bottom ones did not go deep enough or would not sit straight.
However, I did try the reflector without the centering ring and it does get rid of the rings so I think sanding could focus the beam better in my case. My 2020 model is due here today so i’ll wait before I do anything drastic.
2020 RRT01:
Bad:
  • BurningPlayd0h called it. 4000K 70 CRI (the Nichia NW model)
  • The extensions are a better idea on paper than in reality. They are ugly and should have smoothed the top of one so you can have that against the ring. In 18650 form it’s hideous.
  • They used the too long clip (again)
Good:
  • The ring is SUPER smooth, A+
  • Light OP reflector is slightly larger and will be better for LED swaps
  • Barely noticeable detent on floor and ceiling
  • 18350 seems like it’s decent resistance
  • It comes with an extra “gray” switch boot, wrench for clip, extra clip screws, and three O rings.
  • Double springs in tail switch
Neutral:
  • The bezel is slightly longer and the control ring is smaller by that amount
  • Tail stand wobble when off
  • All the silver parts are ever so slightly sand blasted
  • The anno doesn’t match 2019, it’s got a brown hue (this is annoying because you cant switch the head from 2020 to 2019 without noticing this)
  • Face down it’s hard to see if light is on, 2019 was only marginally better though
Reflector (without gasket): 21.62mm x 12.22mm
Lens: 22.81mm x 1.43mm
Lens coating adds –100K CCT and +0.0018 DUV
I used a rubber garden host washer to remove front bezel. Underside of mouse pad or similar can unscrew rear switch housing. MCPCB looks similar to 2019, between 12 and 13mm held in place with 2 small screws.
it is normal for a light with a reflector to have a hotspot,
good for general use, but terrible for illuminating art or for taking photos
I look forward to the details from id30209 on the pebble lens…
For a truly excellent beam with no Hotspot, I recommend the McGizmo Sundrop that uses an Aspheric lens
a similar beam for less dollars can be had from the
Klarus Mi1C aluminium with Aspheric lens
otherwise for lights without the focused hotspot of a single LED reflector light, consider a triple: FW3a
I do not recommend a Mule… imo an Apheric beam is far superior.
oh well… pathetic
thanks for the measurements
proceed with LED swap of your choosing
Well that’s disappointing. Quite the screw up. I’m glad I gave it to my dad. He’s color blind, so it won’t matter to him. :slight_smile:
Thanks for checking.
Jchang76 what did you use to get the bezel off the new one?
Edit; I used a rubber garden hose washer
