I ordered an RRT01 Raptor from Neal on 18th June. Unfulfilled.
Asked via FB on 28th June. No reply.
Asked again today, 6th July, in Chinese. Immediate reply
He’s waiting a few more days for a shipment from JETBeam. He paid them half a month ago.
Neal takes a while to respond sometimes but all the sudden you’ll get a tracking notice when it’s shipped. I got mine shipped june11 which was probably the first batch he got, the others prob went to vendors , i only got in because i had ordered a 2019 right before he listed as discontinued. Took a little over 2 weeks after shipping… quick for Corona standards…
Sit tight!
Found my stock xplhi beamshots before the 219b went in!
Btw my reylight cooper mini clicky 219b seems whiter than my sw45ks. Can someone tell me is this a thing or are my batch a warmer batch? I have a fireflies also is similar white rosy, so with 7 emitters, can't be a fluke?? Anyone know if those run cool? Were they cherry picked for that or maybe my small strip of sw45k run warm? Feedback? So, back to topic, the referred to reylight is pictured below on the right. 2020rrt01 w stock xplhi on left
Maybe i got lucky but i remember the beam being this un-ringy, hence the swap pretty good in that regard...
Stock 2020rrt01 vs swapped to sw40 fenix e20v2 shot indoors at workduring the day.
Here's a pic of the reflector, I'll take better pic when i get in there again to clean some stuff up. i would call it the big opening type with a snug fit up ring.
Here's two stand alone of my 2020 rrt01 after sw45k to compare with contractor's 2019s. (Both pretty low setting, maybe 30%.) When brighter, even less rings. There is a sweet spot i can dial in where i can see some rings from the centering ring to reflector boundary but they don't show up possibly because of my crude photographic method! Im trying! When i messed with white balance, things went south...
Contactor, were your 3 shots 3 different lights or different shots of the same light?
Im thinking the 2020 got new reflector/ other tidbits plus i got lucky.
PS. With this light, everything for swap was accessible from the bezel end... no coming up from underneath, is 2019 / earlier like that? Definitely no fitment issues on reassembly, except for needing to smush down my blobby solders. And pps. The centering ring such a tight fit, i had to remove reflow solder squeezeout for proper seating of the reflector assembly.
Jc
Thx for comparisson photoset.
I wouldn’t bother with the 2019/20 reflector cause it gives perfect beam unlike 2012 even after upgrade.
What i did on one of my 2019 was that i’ve installed Yaijamei TIR instead. Beam vecame just a round hotspot without the spill. And in combination with swapped 351D 5000K instead of XPL-HI is awesome.
thanks for tip about that tir. my main complaint was that i didnt want a thrower or at least such a hot hot and weak spill. i also did not want to resort to dcfix or frosted lenses. but considered pebbled lens. i will likeley try that tir first, did it fit up well? have you looked at that fancy finnish reflector on darksucks site? wondered if that fit, but maybe its too similar to what we are already getting stock.
also, its a pretty mild AR if at all? did you add better AR lens?
I thought I saw this post somewhere but remind me what other changes you had to make. Did you have to get different o-ring or glass? I cant recall
Don't have this sucker with me now but if i'm not mistaken TIR is a tad narrower than reflector opening so you have to be careful when assembling bezel ring.
Lens fits snugly but it fits. Realy nice option to a reflector and i like big hotspot without any spill so i'd highly recommend.
It reminds me of Surefire Fresnel and Olight M2R Pro beams.
I tried a handful of TIRs with a 219B and they were just OK. I didn’t go above 15 degree TIR though. Half the ones I had did not fit at all. It seems the only ones that fit had the very small “lip” on the LED opening. The wide bottom ones did not go deep enough or would not sit straight.
However, I did try the reflector without the centering ring and it does get rid of the rings so I think sanding could focus the beam better in my case. My 2020 model is due here today so i’ll wait before I do anything drastic.
2020 RRT01:
Bad:
Good:
Neutral:
Reflector (without gasket): 21.62mm x 12.22mm
Lens: 22.81mm x 1.43mm
Lens coating adds –100K CCT and +0.0018 DUV
I used a rubber garden host washer to remove front bezel. Underside of mouse pad or similar can unscrew rear switch housing. MCPCB looks similar to 2019, between 12 and 13mm held in place with 2 small screws.
it is normal for a light with a reflector to have a hotspot,
good for general use, but terrible for illuminating art or for taking photos
I look forward to the details from id30209 on the pebble lens…
For a truly excellent beam with no Hotspot, I recommend the McGizmo Sundrop that uses an Aspheric lens
a similar beam for less dollars can be had from the
Klarus Mi1C aluminium with Aspheric lens
otherwise for lights without the focused hotspot of a single LED reflector light, consider a triple: FW3a
I do not recommend a Mule… imo an Apheric beam is far superior.
oh well… pathetic
thanks for the measurements
proceed with LED swap of your choosing
Well that’s disappointing. Quite the screw up. I’m glad I gave it to my dad. He’s color blind, so it won’t matter to him.
Thanks for checking.
Jchang76 what did you use to get the bezel off the new one?
Edit; I used a rubber garden hose washer
Thank you very much for the tests contactcr, glad to see I’m not going colorblind and/or crazy.
Rough idea of what output you took the measurements at? If low, not surprised to see the positive duv but if near the top of the range that’s rough.
High, in the hot spot. I think you don’t notice as much cause the corona and spill are lower DUV and the hot spot on high is a bit bright up close.
Edit; I took out the lens and measured 4043K CCT and 0.0022 DUV so a non-AR lens would help too.
Edit2; 2020 version lens is 22.81mm x 1.43mm (or close enough) and fits pretty snug
I highlighted the CRI R9 (Red Spectrum) above… its a negative number
negative R9 and positive R9 visualized as a Red Bar…
Negative R9 is Bad!
Yikes on cri! Double yikes on r9! This light seems made (at least destined) for swapping. They just threw in the two brightest pos’ they could find so they could write some big numbers, that also have all the brand recognition with em! Haha. Its like my fenix light with sst20. How bad could it be? It was really bad.
I was going to use rubber sheeting that i have at work to remove bezel but my calloused palms were sufficient. Only the pressure of the oring under the glass was holding mine in. The other side was a different story, i got inspired to try my strength on the control ring and cut up said palms.
Also interested in the tir spoken of earlier. Requesting post pic / link when you can please.
Edit-
After undoing bezel many times started with the rubber strips i cut from the sheeting. It’s a semi glossy stiff rubber approx 1/8 thick so it kind of creates a vacuum snd grips the bezel really well.
we think alike
they definitely game the system with the terms Neutral White Nichia
anyway… sales and politics aside… really glad youre getting to swap some LEDs and experience the UI
hope it becomes useful in some niche of your use patterns, thanks for all the info and pics youre sharing
questions for anyone:
is the 2020 reflector the same as the 2019?
is the 2020 driver the same as 2019?
woah!
I was not paying attention when you said that the first time
thats nasty, but interesting
whats the tradeoff if we remove the coating?
what percent of output lost?
what to use to strip AR coating?
is that too many questions? LOL
when I got sapphire lenses for some V11r, I noticed they seemed clearer (maybe just clean)… but they seemed to lack AR coating, no purple/blue/green reflection from the suface of the glass.
The reflector is definitely not the same, as the 2019 version was smooth and the 2020 in OP. Also, the 2020 has a bigger LED oppening and a different centering gasket is used. Finally, I did not put them next to each other, but believe that the 2020 reflector is larger in both dimensions. The 2020 creates a much smoother beam, with no rings or artifacts that I can see.
The driver is the same, I have both seen it and had it verified by Jetbeam that they have not changed the driver. It is a pity they did not take the opportunity to address the driver’s shortcomings.
An LED swap to Nichia 219b sw35 has created a far better and usable light than I ever expected, given the increased bulk.
Now, I am thinking of adding trits in the tail lanyard holes. They are too short for 6mm x 1.5mm trits but will fit 5mm x 1.2mm trits fine. Does anyone know the best method to do that, since the holes are open on both sides? I am thinking of running electrical tape on the inside, install the trits, cure the glue and removing the tape. Any better / tried methods?
LED swap:
Shaved LH351D 5000K from AEDe’s last batch
I cut flat parts on the centering ring so it would not “rock” against screw heads and clear my solder blobs. It sits nice and even now.
The spare garden hose washer you get with sprayers and hoses to work with bezel.
Very nice result. This is on high, in hot spot, using stock glass. If I replaced the glass it would be even lower DUV.
lovely
thanks for the pics
do you know the percent change in output after swap?
