I certainly wouldn’t mind winning one of your 14500 batteries, Thanks for the giveaway!
14430 920mah? That’s not a bad cell!
But if I win, I’d like:
18650 3500mah P1835A button top USB battery ,Internal Resistance Max:35mΩ (AC 1kHz),Fast Discharge Current :8000mA (8A)
or
16340 850mah 3A T8 button top battery ,Internal resistance Max:65mΩ(AC 1kHz),Standard Charge 500mA,CCCV 50mA cut-off
I’m not yet sure.
Thank you for doing this Vapcell!
You would certainly make me happy by letting me win the: 18650 30QT 3000mah 20A
Thanks for doing this. vapcell Dennis
I would like 14500 1800mah 1.5V AA size USB battery button top ,Built in battery li-ion INR14430 920mah 3.6V.
I would love the “original Samsung 30QT 3000mAh 20A 18650, new upgraded version, high power discharge, long cycle life”
Thanks for organizing this giveaway!
Thank you for the giveaway, vapcell Dennis!
I would be interested in the #4. 18650 3500mah P1835A button top USB battery.
Thank you for the giveaway, vapcell Dennis - please count me in.
I would be interested in the 18650 30QT 3000mah 20A battery and, if I am one of the lucky winners, will most likely buy more from your store!
Hi, would really love a 26350 2000mah 6A for my little fatty!
18650 30QT 3000mah 20A , original samsung New upgrade version would
Light up my (immediate) world, thank you!
I need 26350 , #1.
4 of them actually
thanks for the giveaway, could use the #6. 16340 850mah 3A T8 button top battery
Hi Vapcell Dennis
I would like to have a 14500 1800mah 1.5V AA size USB battery button top.
Is this a real 1800mah for the size AA battery?
Am I late ?
I am in search of 16340 850mah 3A T8 button top battery
Thanks for the give away
4 30QT if we can choose multiple. If not I’ll change it if I win.
Thank you so much. I love 18650 30QT 3000mah 20A
Nice to have a new option for the Fitorch! I’ll probably order some in the hope that running the P25 with 4xSST-20 won’t trigger voltage warning anymore. Still works, but the red blinking switch makes me nervous.
Thanks again, Vapcell, for always with us and for your GAW.
I want #3 14500 1800mah 1.5v.
Thank you for the giveaway! For me the 18650 30QT 3000mah 20A as well, please.
Thank you for GAW.
I would like nr. 2. 18650 30QT 3000mah 20A , original samsung New upgrade version,high power , long Long cycle life
I could also definitely use some 18650 30QT 3000mah 20A. Thank you!
