RD tech, now that there’s an iOS app for the RD6006 is there any chance of one for the DPS series?
IOS APP download: Search RdPower to download , support IOS8.0 and above phone
no , they have different app
RD6006 customer reviews
Packed in a box in polyethylene with bubbles. It works up to 60V. Naturally, it will not be able to deliver above the applied voltage, because it is a buck mode, there is a separate "+" jack for battery charging connection.
www.aliexpress.com/item/4000282551930.html
The items were just as described. Best packaging. Device assembly was straight forward and there was exactly correct amount of all components. With suitable power supply the device worked correctly.
RD6006W customer review
Everything is packed, very good, the body is in polystyrene foam. Thank!
the module is just super! The build quality and soldering at the highest level! Low ripple and high accuracy of the output parameters, I am delighted! Thank you seller.
welcome to have a look at our company, you can see how RD6006 comes out
www.youtube.com/embed/gxe9YiLCR0o
Works perfect, fast shipping and no customs tax(it depends on your customs), excellent seller, 100% recommended
The product arrived well packaged, everything perfect and consistent with what is written in the advertisement. I am satisfied, very good. delivered before the deadline, thank you.
All excellent super recommended
(seller: if you are charging battery, you had better to use the battery charging terminal, I see the settings, 4.2V is peak voltage for one 18650 battery)
the packaging is great. satisfied with the product. thank. the power supply will come and write in more detail. and you need to purchase the battery separately.
Are there any plans for this kind of unit to be available in a higher current? I love the DPS5020 and have been considering it, but I really like the interface on the RD6006, along with the case to hold it all with the PSU.
thank you so much for your reply , there will be 18A and 24A version in the future
Fantastic! I’ll keep an eye out for them.
thank you
excellent laboratory worker, there is a lot of information on the internet
Good build quality. Very efficient design. Used in as workbench power supply
RD6006 customs reviews
Working. It is packed perfectly. Recommend seller
Really good quality! Ewerything is there what you need to mount! Highly recommended! Thank you Seller!
Great seller! great power supply! fast delivery from Russia warehouse! easy to assemble!
