Not for me, and that is because of the battery, the short version for me looks like it lost 65% of the capacity. I believe that only a smaller built flashlight justifies the use of a 18350 battery.
Btw I have the 5000K SST-40 version, the beam it makes is very good without any obvious artifacts or tint shifts, on a 30Q I measure 1800 (honest) lumen at 30 seconds ( :+1: ), the tint is pleasantly neutral at low output but rather purple at high output, the CRI as expected is low, about 66 and at lower settings the CCT is 4700K. The colour leds in the reflector make for a neat effect.
It is the nature of this led. The turbo tint is not different from the significantly lower top ramp setting tint. To be more precise, the purple-ish is in the spill and not in the hotspot.
Depends on the colour of the coating, the tint can go anywhere. The green coating of my D80V2 actually works as a minus-green filter, a purple coating removes some red and bluecand so effectively makes the tint a bit greener. I have not seen red or orange coatings (apart from non-functional coatings on very cheap chinese binoculars), those would make a tint cooler.
