Major design change:
In conjunction with the multi-emitter flashlight concept that is being discussed here, I have revised the WK30S concept to work with a magnetic control ring and a mechanical tail switch. This will probably make the rather complex UI much more easier to handle.
User Interface:
Magnetic Control Ring (MCR)
- controls brightness from moonlight to high steplessly for the selected LED
- infinite turning into either direction is yet to be decided - a limited turning angle of 160° could maybe suffice to regulate brightness conveniently
Tail Switch (option A - forward clicky)
- Tap to preselect the mode (WHITE / RED / UV)
- Fully press to turn ON/OFF
- Half press to use momentary mode
- Keep fully pressed for 2s to activate strobe, then tap to cycle strobe modes (SOS / Beacon)
Tail Switch (option B - reverse clicky)
- Tap to cycle through modes (WHITE / RED / UV)
