Didn't try yet - maybe can try this eve.
It simply unscrews from the body. I used an elastic band on the bezel for better grip.
Pressing the bezel against the sole of a shoe while unscrewing should also work. Takes a little force but will come off.
I removed the bezel easily with my sticky gloves.
Interesting fyi, I added 22 AWG wire bypasses on the springs (short ones in the center of the spring), and got ~ 25% boost in lumens and candela.
Measuring amps at the tail, on a charged up 40T the amps went up from 14.7A to 16.5A, but that's only seeing the bump of the bypass on the driver side because my amp measurements are with the tailcap off. I did the before/after tests with both a 40T cell and a red Dolidada 5500 26650 and saw about the same percent bump. These springs are not high performance, accept maybe for their thickness but they are not low resistance.
"nnnn-nnnn" below is "at start - at 30 secs"
Before After
Sam 40T 4390-3890, 32.5 kcd 5340-4790, 40 kcd
Dolidada 3530-3270, 27 kcd 4450-4180, 35.5 kcd
25% bump from bypasses? Wowsers!
We've been get'n spoiled on the high qual springs and double springs in our lights as of late - these are standard springs. I'd be worried about melting them with a good cell without bypasses.
Confirmed - went from 2200 lm in kit spec (kit 26650 and everything out of the box) to 2820 lm with bypass (2x 22awg twisted ends, soldered to spring).
40T was getting 2635; up to 2965 w that bypass.
Anyone took a picture of the driver spring? I’m not sure where to solder.
I took the spring out before soldering it; just gotta “compress” it sideways at the bottom to do so.
And yes that’s two wires
Thanks a lot!
But I meant the Spring on the driver PCB
Oh! Oops!
I’d probably do something similar - gotta desolder the wires to the MCPCB first to get the driver out though; they’re quite short.
Ok, you only bridged the tailcap spring and that is already very successful. Good to know, I’ll try this
I solder the bypasses inside the spring - if the solder joint breaks, you don't want that wire touching something it shouldn't on the driver side.
Though the outer bypass has advantages - the spring can completely collapse down if a battery fits tight.
On the driver side I’d do my best to do it on the inside (would spend more time on it than I did), but for the tailcap side, it’s all one slab of metal so I figured it was fine for the outside.
It’s unfortunate that “3500” ended up being 2200, though.
Yes, this is my concern. I have a 20700 for the SP33. Maybe I need to go back to the 26650. Or leaving the spring on the driver side untouched.
2200 is much lower than mine before the bypasses. By out of the box, do you mean the battery out of the box as well, not fully charged?
Sorry, no - fully charged, but the kit battery. Have tested in both a lumen tube and sphere, both calibrated with lights from Maukka.
Also some crazy thermals.
Is X in minutes or seconds? My lumens measurements are in "Tom E" calibrated lumens which is 12% higher than Maukka cal'ed. Just subtract 12% from my #'s. I didn't get their kit w/battery though.
My "Tom E" units were originally based on manufacturer ratings, but leaning towards the manufacturers that are higher end and consistent. It's rare to see any manufacturer come close to Maukka rated lumens. I try to give the manufacturers benefit of the doubt by still using "Tom E" ratings rather than Maukka cal ratings, but comparisons on BLF here is better to use Maukka ratings. For me it's easy though - 12%, that's it. I did have the Maukka cal lights to calibrate my PVC lightbox by.
I’ve gotta say… I did a couple updates to my lumen tube and set a new conversion factor (using my TO50R as a trusted source, alongside Maukka’s confirmed measurements of the TO50R) and I’m now showing 2200 lumens with my SP33 V3 as well
Ah, sorry. X is minutes; just grabbed that from my google sheet.
This is a closeup of the first 20 minutes on High (my labelling is garbage):
