It did ask for a refund over and over but they refused , because their ātracking showed deliveredā, and I couldnāt get my money back from PPal as well. Someone here mentioned that they play games with reusing tracking numbers and that way if it gets lost they are not responsible. Could be bad luck but it left me with a bitter aftertaste.
Was the delivered address correct? If not, then you should have a case. If the tracking number still shows an older delivery, they may have given you the wrong number. Again, that should be their fault. They cant say it got ādeliveredā and the delivery address not be yours. I assumed you plugged the tracking number into at least 2 or 3 tracking services. Sometimes one tracking service is not up to date.
I donāt know what country your in, but I know some countries can be really bad with foreign deliveries.
All tracking numbers get reused so that person is probably not aware of that and assumed it was something malicious.
I never had a tracking problem with them, but Iām in the US. Then again, I dont always check the tracking unless it hasnāt shown up within 3 or 4 weeks.
I can understand if you feel screwed over. Astrolux is Banggoods house brand, but if they use Mateminco to build it, Mateminco will sometimes do their own version. Itās exactly the same product, just a different brand and sold in different stores.
I forget what you were originally looking for, but I think it was a med size thrower? There are definitely other lights out there around the same size as the FT03, but they are more basic or else cost more. FT03/MT35 gives you a lot for your money. Iām sure there are threads on mid size throwers here.
The address was correct,
I was looking for a thrower that would fit in a C8 holster or something similar.
Will check out the threads. Thank you again and I really appreciate your time.
Who knows how to get in contact with Nightwatch (the flashlight brand)? My Taobao chat tool does not work currently. I would have a few questions about the NSX4.
Other manufacturers have an Aliexpress store or even a BLF account where you can bother them with questions. With Nightwatch I never found any other possibility to contact them apart from their Taobao store.
I know the SBT90.2 is a nice competitor but only because itās a 3v led instead of a 6v led like the XHP70.2.
The latter one has still a higher (potential) output.
Using a 6v led isnāt a problem, only need to find a suitable driver for it to drive it with some decent amps. Somewhere around 8 or 10A.
Still need to figure out the cell configuration. Right now I was thinking to use 2s high drain 18650ās. Though might change it to 21700ās, however that would require some major redesign.
Cree CXB3590 will do about 16,000 lumen. Its 36v so you need a boost driver and a 12v source. The one driver I know of uses a rotary knob instead of a button. So not very practical.
As far as āregularā leds itās the 70.2 as it can be driven at around 20 amps at 6v (over 6,000 lumen). At only 8 to 10 amp it is around the same output as the 90.2 when it is pushed hard, about 5000-5300 or so.
Newbie here, with my first of (likely) many stupid questions. Iām close to pulling the trigger on an Anduril UI driven light, but Iām excited for many of the muggle-friendly features discussed in ToyKeeperās Anduril (Rev 2) update. When Anduril Rev 2 is released, will there be an easy way to update current Anduril UI with the new operating system? Thanks!
There is no easy way. Youāll need to reprogram the MCU. Some lights need a clip and some use pins to make the contact. Some lights need to have the driver removed, some donāt.
3535 boards are extremely common - though 14mm is an unusual size.
I know some 4040 LEDs have been reflowed on 3535 but it is very challenging and probably reduces performance. If I couldnāt find 14mm 3535, Iād file down a 16mm.
What happens if you stack an extra 7135 on a fet +1 driver? Would it matter if its the BLF A6 fet +1 driver vs the Mtn fet +1? Is it as simple as, low mode is now ~700ma instead of 350? or something else? Would different firmware change the result of doing this?
What about if you soldered on a slave board of 5 or 10 7135ās instead of just stacking one? Same result, low mode is now whatever the 7135ās put out?
Those COBās are indeed very high output in a single package. That driver does sound interesting, do you mind sharing that driver?
Though I was talking about the āregularā leds. So the 70.2 is still king of the leds when looking at raw power.
After some driver search I think itās better to go to 12 A. It gives a nice boost in output and would still be doable.
Unfortunately my power supply only goes to 5 A so cant test the setup at those power levelsā¦
You basically have the right idea. The 7135 channel outputs a PWM signal designed to produce a certain brightness within this range of 0.35A. Do keep in mind that it will screw up the brightness ramp. Like the Low mode may now be as bright as the Med mode. So what used to be Low Med High may now be closer to Med Med High. Youād need to change the firmware to get the brightness ramp back to being smooth. This is why no one really stacks 7135 chips on FET+1 drivers.
The whole point of the extra 7135 channel is just to get a lower moonlight level. A single FET can do the whole range of brightness, but moonlight is a struggle to be dim enough.
I would consider the Sofirn SP33 v3 3500lm. It has a ramping mode, 5000K or 6500K, usb charging, is bright, decent throw, good size hotspot, 26650 size gives long runtime and handles heat well. Budget friendly price.
