Sofirn S11 Zoomie
There is no ramping, it steps between modes.
so is it a steping mode or smooth ramping?
If anyone wants to try, found the stuff cheaper somewhere else: https://www.aliexpress.com/item/4000294614311.html
Also, nice sale price with the following link besides an (awful) different version: https://www.aliexpress.com/item/32960591645.html
Or maybe it is 0K?
Stepping modes.
I also have that one, not as good.
Oh man…so glad I only purchased 2 for $10.58 nzd each. I’ll just gift them
Thanks HenrysCat
Ill skip this light :slight_smile:
Hi, this is from sofirn s11-b.
I’m just a new, so I don’t know this is called ramping or not.
Mode Group 3: Ramping actually works okay, it’s smooth ramping too
Click - High
Hold - Ramping (flashes twice at floor and ceiling, if already at highest it will still flash before ramping down)
Click - Off
2x click - Strobes
While off
Hold - moonlight, release and hold ramps up
Release and hold will reverse direction
Group 3 is not bad at all, I expected worse. Just wish it stored the ramp setting but still nice you can start first at Moon
Group 4
Click - High, Med, Low, Strobe, Sos
Click - Off after a level has been on more than 3 sec, otherwise cycles to the next level
While off
Hold - Moon
Click - Off
Group 5
Click - High
Click - Off
While Off
Hold - Moon
Click - Off
_
If the lens was fixed it would be quite okay
EDIT: Some artifacts while zooming but after playing I actually prefer the frosted lens rather than a square
I like your design changes (LH361D is my preferred emitter - 5000ºK).
Change the frosted lens to an aspheric for focus and this may be a good zoomie.
And look into the USB cover to not get caught when slipping into a pocket.
I hate the frosted lens, ruins it.
The flap hasn’t been an issue for me
837 lumens measured at 30 seconds
I just got mine in today after ordering it 15 days ago… that was fast! Looked good BUT one side has a scratch going across 1/2 the light… 3 stars :expressionless:
I didn’t have time to take it outside tonight, but ran a quick test with Sofirn button tops (3000mAh 18650s), and it ran fine for a short bit. I tried my solder topped 30Qs and they were not long enough to make contact to turn the light on. The Sofirn batteries barely did it and shaking it wigged it out as it was too loose still. I grabbed a 21700 and it almost went into the tube, but not quite. As you can imagine there is a lot of rattling too.
The rear spring is a joke that looks like it came out of a ball point pen. Looking down the tube from the rear, what I see is a solid brass looking contact (very wide), so no spring. I’ll probably go digging into the parts box for a better clicky switch for the tail while replacing the rear spring (and bi-passing it while I’m at it).
The zooming is decent but probably not a light for wet weather. Lens looks nice and LED is centered. Focus goes down with a fairly even beam throughout while going from wide to zoomed. With a few small tweaks it will make a cool little zoomer for fair weather outings. More time will tell and I’ll update after the first round on the bench here in a few weeks when I get a rainy day.
Thanks again HCat!
What?
I purchased 2pcs and 65mm flat top cell fits snug, only a rattle if I shake really hard.
Springs at both ends
Sounds like you got a lemon
Frosted lens is much better than focusing into a small square of the led. I actually prefer the frosted lens since you get a good amount of surround light as well.
Great around the house edc
This thing scratches really easy, I scratched mine by just moving the clip to the side.
Hum, I guess I just expected cheap! :stuck_out_tongue:
So upon looking again… up the tube- I see where a cold solder point probably held a spring. But someone assembled it broken since no spring fell out when I initially open it. The new Sofirn IF25a has a wide, brass contact behind the driver and I was used to seeing this the last few weeks (as I’m playing with both the 5k and 6.5k version lately). But ya :person_facepalming: - I now realize that is why batteries weren’t long enough and it rattled like hell.
I contacted the seller and might have to send pics, but it’s not right and so I’ll see what they can do for me. Again… thanks Funtastic for the heads up :+1:
So what’ll be?
I changed my mind after actually using it to walk the dogs. I have never used a zoomy that doesn’t zoom into a square so at first I hated it.
I was thinking of adding it to my website to sell but it just feels too cheap.
- Button sometimes clicks twice as if the button isn’t centered correctly, or there’s an issue with the switch. Same thing on both my lights
- 1pc the led isn’t centered and no idea how to dismantle it.
- Scratches really easily
- rotating head doesn’t have enough lube so it squeaks, again no idea how to dismantle.
- Full flood or full zoom is okay but anything inbetween is full of artifacts
  • Hard to locate the button by feel
Good light for gifting but that’s about it.
Sofirn needs to design their own instead of messing about with something cheap.
@ Funtastic:
If Barry can get the proposed changes, and maybe some quality issues resolved, I’d like a zoomie. Never thought of converting one of my cheap 3xAAA zoomie with a frosted lens though. Always used the die projection as a pointer.
Hmmm, High of 837 lumens lasts 35 seconds and then drops to 50%.
I’ve got some Convoy Z1’s on their way, really hoping they’re decent
