Anduril ... 2?
It would be great to have a lightshow sequence just like the Tesla :partying_face:
Crazy…
Put microphone in flashlight, make it flash to music.
Then Facebook will buy it out and use it to spy on you.
if it hasn’t been said fork it. anduril and simplified version with new name ( i’d suggest Mjölnir ).
Have been making some good progress today…
  • Removed muggle mode, and replaced it with a “simple UI” overlay which restricts which actions are available
  • Made simple UI enabled by default (and after each factory reset)… unless the config file specifies otherwise (so it can be default or not, per build target)
  • Made it so the simple UI use a smooth or stepped ramp
  • Created configurable floor/ceiling/steps vars for simple UI, but didn’t add a menu to actually configure it yet
  • Refactored a lot of ramp-related code
  • Made battcheck exit after one readout, when in simple UI
  • Added 4C from lockout to on (mem)
  • Added 4H from lockout to on (floor)
  • Added 5C from strobes to momentary
  • Moved all aux LED / button LED config actions to 7C / 7H, to make it consistent
  • Moved all config modes / menus to 7C, to make them harder to reach by accident (also, more consistent with aux config)
  • Removed beacon config mode… basically, instead of “click N times” to set the timing in a menu, it’s “hold for N seconds” to set the timing whenever beacon mode is active
  • Reduced overall size by 190 bytes
There is still much more to do, but this has been a good start.
add the best function from the Narsil software, i.e. the ability to disable thermal control will save a lot of trouble for some models and their users
I’m scared of the idea that it’ll change because to me it’s soooooooooooo perfect already
This sounds very promising.
In stepped mode would be nice to have ability to control space in between steps. Fo example 1ma- 5mA - 20mA 50mA - 350ma - 1A - 3A
my understanding is individually programmable modes (steps) are not something Anduril is going to offer.
see
UI with individually programmable modes will be the best and ultimate UI ever made . Everyone will be happy :laughing:
I think ‘simple’ mode should be more simple. Really basic. Click on, click off, or hold to ramp. That’s it. After all, that is really the only thing a muggle will be interested in. We flashaholics are so used to fantabulous features, we’ve forgotten what it was like to be a muggle. Anything but on/off/change levels is more than they want to absorb.
Not that I loan out my flashlights enough to make it matter to me personally. But I gave away a Nitecore EA41 recently along with a copy of the instructions, and the couple was intimidated by the fact that “it’s so complicated, it comes with instructions.” :person_facepalming: That really made me stop and think. The EA41 UI is not complicated.
Personally, I think it’s getting to a point where we may soon need to add in a feature where we click/hold a certain number and the light projects (in the beam on a white wall) the instruction manual! :laughing:
The steps aren’t individually-programmable, but they do accelerate up along a curve like what you described. They are spaced evenly along the ramp, but the ramp itself is curved.
The curve shape is different for each light though, calibrated to make it feel similar despite large differences in the underlying hardware. Except, of course, on lights where the manufacturer didn’t bother doing that and just copied firmware from another light. Those end up with weird ramp shapes and sub-par thermal response.
There are lights which work this way. They typically either come with a separate configurator app (which isn’t possible for most Anduril-based lights) or they take a long time to program… like an hour tapping buttons with the manual. Most people never bother configuring those because it’s too complicated.
However, a separate UI could be created which allows each step to be whatever the user wants. It could also allow user-defined button mappings similar to the YLP Unicorn. I think Inferion had a good idea there, and really put a lot of functionality into a small space. But if something like that is made, it would be a different UI, not Anduril.
One of the things I’m doing with Anduril2 is to break the code into smaller pieces so it’ll be easier to maintain and easier to reuse parts in other UIs. So that may be helpful when attempting to create something more configurable for power users.
That’s a big part of why I made this thread. I’m hoping to answer the question of “what should the simple UI be like?”
The old muggle mode was just click for on/off and hold to ramp. Or a longer button sequence to exit. Nothing else. But people often said it was too simple, and they wanted to be able to check the battery status or lock the light or configure the ramp so it wasn’t stuck at factory settings.
So for now, that’s basically what the new simple UI is. The currently-enabled functions are:
  • Ramp:
    • Click for on/off
    • Hold to change brightness (or press-release-hold to ramp down)
    • Double click to go to/from the top level (no turbo)
  • Battery check (3C)
  • Lockout (4C)
  • Long button sequence to go to advanced mode
  • Even longer button sequence to check the firmware version
  • Factory reset (hold button a few seconds while inserting battery)
It also respects settings configured in advanced mode, like the smooth/stepped ramp style, manual memory vs automatic memory, and (eventually) floor/ceiling levels. But those require going to advanced mode and back, so they don’t really affect anything for muggle purposes.
Are these the right features to have in simple mode? I don’t know. That’s what I’m hoping to find out.
[quote=ToyKeeper]
I’d remove the lockout. It is not really necessary, and might be a pain for beginners to get out again.
However, the battery check is a very useful feature, and not problematic when activated unintentional.
If lockout is disabled by a power cycle I don’t see the harm of having it there.
I would love to use the simple mode most of the time, and on lights like the ubiquitous FW-series, physical lockout is not an option. Electronic lockout is needed.
Why not? I do it on mine. Yes I understand that it only disconnects the switch and not the actual power; but it prevents accidental activation, which is the goal yes?
Mine needed nearly a full turn to disconnect the switch signal which wasn’t practical when I actually needed to use it. Considering they have been known to randomly turn on at full power when things go wrong, even that doesn’t inspire a lot of confidence in me either TBH.
Off topic but running it without the metal switch cover was 1000x better for me personally. No lockout needed, switch was recessed and took more force to press (but not so much that rapid clicks or holds were difficult) and felt very satisfying and responsive. Once Lume1 is out I’m definitely getting an FW1A and running it like that.
Ahhh gotcha. Are you turning the tailcap or the head? I did the head and don’t recall having to turn it that much, but I traded away my FW’s.
The head. Mine is from the first GB and doesn’t have the tailcap retaining ring.
The FW3A (and presumably other related models) has a lot of variability from one light to the next. One of the things which differs is how it responds to having the front half loosened. On some, it’ll cut power in a quarter turn… while on others, it must be unscrewed completely off. I have examples of both in my collection.
So… yeah, sometimes soft lockout is the only option.
I’ve pondered whether lockout should be on 3 clicks instead of 4, to make it faster to enter/exit. Then I guess battcheck would be on 4 clicks. Not sure if that’s how it should be though, or if the current setup is better. However, it would definitely be one of the more difficult changes to get accustomed to. I know we’re breaking backward compatibility here, but swapping those two seems like it would be particularly annoying for anyone who has lights of both the old and new versions. We’d trip over it constantly.
