That’s a big part of why I made this thread. I’m hoping to answer the question of “what should the simple UI be like?”
The old muggle mode was just click for on/off and hold to ramp. Or a longer button sequence to exit. Nothing else. But people often said it was too simple, and they wanted to be able to check the battery status or lock the light or configure the ramp so it wasn’t stuck at factory settings.
So for now, that’s basically what the new simple UI is. The currently-enabled functions are:
Ramp:
Click for on/off
Hold to change brightness (or press-release-hold to ramp down)
Double click to go to/from the top level (no turbo)
Battery check (3C)
Lockout (4C)
Long button sequence to go to advanced mode
Even longer button sequence to check the firmware version
Factory reset (hold button a few seconds while inserting battery)
It also respects settings configured in advanced mode, like the smooth/stepped ramp style, manual memory vs automatic memory, and (eventually) floor/ceiling levels. But those require going to advanced mode and back, so they don’t really affect anything for muggle purposes.
Are these the right features to have in simple mode? I don’t know. That’s what I’m hoping to find out.
I’d remove the lockout. It is not really necessary, and might be a pain for beginners to get out again.
However, the battery check is a very useful feature, and not problematic when activated unintentional.
If lockout is disabled by a power cycle I don’t see the harm of having it there.
I would love to use the simple mode most of the time, and on lights like the ubiquitous FW-series, physical lockout is not an option. Electronic lockout is needed.
Why not? I do it on mine. Yes I understand that it only disconnects the switch and not the actual power; but it prevents accidental activation, which is the goal yes?
Mine needed nearly a full turn to disconnect the switch signal which wasn’t practical when I actually needed to use it. Considering they have been known to randomly turn on at full power when things go wrong, even that doesn’t inspire a lot of confidence in me either TBH.
Off topic but running it without the metal switch cover was 1000x better for me personally. No lockout needed, switch was recessed and took more force to press (but not so much that rapid clicks or holds were difficult) and felt very satisfying and responsive. Once Lume1 is out I’m definitely getting an FW1A and running it like that.
The FW3A (and presumably other related models) has a lot of variability from one light to the next. One of the things which differs is how it responds to having the front half loosened. On some, it’ll cut power in a quarter turn… while on others, it must be unscrewed completely off. I have examples of both in my collection.
So… yeah, sometimes soft lockout is the only option.
I’ve pondered whether lockout should be on 3 clicks instead of 4, to make it faster to enter/exit. Then I guess battcheck would be on 4 clicks. Not sure if that’s how it should be though, or if the current setup is better. However, it would definitely be one of the more difficult changes to get accustomed to. I know we’re breaking backward compatibility here, but swapping those two seems like it would be particularly annoying for anyone who has lights of both the old and new versions. We’d trip over it constantly.
This definitely sounds like a good idea, hoping that I can flash my D4V2 flashlights with this new Anduril.
I can also vouch for a more subtle candle mode, it’s a bit too violent at times.
It can also be a bit repetitive, but that’s probably a memory limitation.
Although it’s a lot better than many flickering LED candles I’ve seen.
No doubt Anduril is the best flashlight UI made so far, I rarely justify buying a light without it. If so, the light should be pretty special (like Nitecore TUP with the OLED display).
Candle mode could definitely benefit from higher resolution in the brightness ramp… and more frames per second… and some adjustments to the overall algorithm. It also varies from one light to another, since the underlying ramp is different. I try to adjust it to be fairly consistent, but it doesn’t always come out quite right.
About low/med/high/off, that’s possible by using the stepped ramp. Set it to 3 steps. It’ll still have the blinkies and other modes available though…
… so there’s also a simple UI, and it inherits the ramp style (smooth/stepped) of the full UI. It just has safer limits and most of the other modes and functions are blocked. The code for that isn’t published yet though; I’m still working on it.
I would also like a very robust simple mode where 1C and 1H dont make any difference. Nothing else, no ramping, no lockout or any click sequence that may make the flashlight behave strange. Simple enough that you understand it after just a few clicks.
An option to set the UI just on/off to a safe but useful level - like good old lights, would be just enough in some instances.
PS: and if it was possible to make the light flicker when you shake it it would be perfect!
For a ‘simple’ mode that is easy for muggles, a lockout mode presents the possibility of accidental lockout. And a muggle might never figure out what went wrong, and assume the light has died.
That’s why I’m not sure if lockout should be included in the simple UI.
However, I don’t think they’ll assume it died, because the LED turns on while the button is pressed. It just doesn’t stay on. And if they loosen / tighten the tailcap, it exits back to the regular non-locked “off” mode.
I may try to rework the ramping code a bit to allow for a single-brightness ramp. It might be a bit of a pain to configure, but afterward it should be able to do just on/off without changing brightness.
It’ll probably still have the battery check available though, and maybe lockout… so it’s not quite a 1-function light… but at least sort of similar.
I would support that change, despite the potential for confusion. (And I think a lot of us will upgrade most or all of our lights once the new version is out, which will help.)
For reasons I cannot adequately explain, I can do a very fast triple-click every time, but four clicks is either much slower or a lot less consistent. I asked a couple of other people to try it too and they had similar results. Doubles and triples seem to be built into the human nervous system, at least for some people, while anything beyond that requires counting. Does anyone else have a similar experience?
So moving lockout from 4C to 3C would actually make a big difference, at least to some of us.
