I realize this is crazy talk, but my ideal version of Anduril would have configuration options to enable or disable access to almost every feature from “simple mode” individually. It would let people create the interface they want to use while eliminating anything that might cause confusion. (Note: I would still limit all configuration options, including these, to the advanced mode.)
Features I would make selectable include:
Moonlight Shortcut
Turbo Shortcut
Ramp vs Step Toggle
Lockout
Momentary Mode
Blinky Group
Strobe Group
It would be even cooler to have control over individual options within the groups, but that is probably going too far.
I have no idea how hard it would be to implement something like that, but it would sure be fun to have.
I’ve heard from a couple people that they can’t reliably get 4 clicks or anything above. Like, there’s a difficulty with counting the clicks at the same time as actually doing them. That’s part of the reason for removing extra functions, so it’ll be harder to hit the wrong function by accident.
I haven’t really had difficulty with it, but I don’t really count… I treat it more like a musical instrument than like a counter. This makes it fairly easy to count pretty high without really paying attention, as long as the desired end number lines up with a musical phrase or a song. Like, if something needs a count of 96, that’s easy… just play a song in my head which has 96 total beats (usually 3 sets of 4x8 beats), and at the end of the song I’ll have the correct count. Need to count to 400? Same thing… just go through the song 4 times, and then add 2 extra 8-beat measures.
For a flashlight-specific example, there’s the factory reset function on 13H. For that, counting is hard but rhythm is easy. It lines up perfectly with the beginning of a song from DOOM:
Or another easy way to count it is more like 1234 1234 1234 5… or a rhythmic version of the same:
In the config modes, if I need to enter a large number and it doesn’t line up with a song, I’ll usually just break it into groups of 10. Like, a count of 31 is easy since it’s 1 less than a song pattern so I can just stop one note short of the end. But if I wanted 52 or something else that doesn’t line up easily… so I’d count it out in a more traditional way:
I’m not sure what methods other people use though. It seems like actually counting would be difficult, but there are usually easy ways to count short sequences without explicitly thinking the numbers.
Would it be possible to have a “version check” similar to “battery check” ? There seems to be no simple way to determine what version of Anduril is on the flashlight.
I don’t think that will fit on most attiny85 hosts, but it could be done on chips with more space.
The way it works now is, in a few of the modes (like “off” and “ramp”), it checks for button presses which are supported in simple mode… then if simple mode is enabled, it returns. If simple mode is not active, it then checks for button presses which are only allowed in advanced mode.
This could be changed to instead check for simple mode and the specific feature’s simple-mode toggle, on each button press. It would increase the code size though, and require several extra vars stored in eeprom, and a much longer config mode of some sort to let the user set each option.
So it’s doable, but a bit messy and probably won’t fit at the same time as other stuff I’m hoping to add.
I think you should be able to set the max temp by holding the light until it gets too hot, then turning it off, like some other firmwares. I found the temp settings difficult to calibrate for some lights. Also, yea the framerate for candle mode needs to be higher. You might also adjust the range so it doesn’t flicker quite as high when its turned down. At higher brightness this is not as much of an issue.
The reason why it uses a numeric entry for the temperature limit is because “hold until hot” didn’t work very well in the past. So I’m not planning to go back to the older method.
However, it has an auto-calibrate thing built into the factory reset function, and it usually works pretty well. It’s quick and easy and sets the limit to 24 C hotter than whatever temperature the light is during the reset.
If I may make a suggestion, I would like some way to set the brightness of the auxiliary and the switch LEDs on my D4V2 Ti. The dimmer option for these is way too bright for nightstand duty but turning them off does not help with locating the light in the dark.
‘Hold until hot’ is very hit & miss. Sometimes you specifically want the limit to go up or down slightly, that is very difficult with the ‘hold until hot’ method. On one attempt the limit goes up, on another it goes down, sometimes by far too much. There is a lot of trial and error to achieve the desired result.
To be able to just go in and accurately + or - the limit is so much better.
Please make LITE mode such way that after randomly sequence of clicks and holds made by kid or not flashaholic friend you don’t need to think “aaaa! what he did with my flashlight!!11”
Sorry, I can’t do that in firmware. The brightness is determined by hardware, not firmware. So there are only three brightness settings:
High: Power on, internal resistor off.
Low: Power on, internal resistor on.
Off: Power off.
It can control whether the power is on or off… and whether the control chip’s internal resistor is added into the circuit to reduce brightness. But it can’t control how much.
Instead of a few short menus attached to the mode they configure, at 1 to 3 items each… you would prefer one long menu with about 10 to 20 items?
At last count, there were 21 config values… of which about half are set from a menu and half are set using some other action. The number changes over time though, as things are added and removed.
How would people configure lights which are physically incapable of this?
It uses “hold while connecting power” for factory reset, on most lights… so it would need another way to do that. And it would need to be really easy to do, since it’s a safety net for new users.
