Packed in a box in polyethylene with bubbles. It works up to 60V. Naturally, it will not be able to deliver above the applied voltage, because it is a buck mode, there is a separate "+" jack for battery charging connection.
The items were just as described. Best packaging. Device assembly was straight forward and there was exactly correct amount of all components. With suitable power supply the device worked correctly.
the module is just super! The build quality and soldering at the highest level! Low ripple and high accuracy of the output parameters, I am delighted! Thank you seller.
The product arrived well packaged, everything perfect and consistent with what is written in the advertisement. I am satisfied, very good. delivered before the deadline, thank you.
(seller: if you are charging battery, you had better to use the battery charging terminal, I see the settings, 4.2V is peak voltage for one 18650 battery)
the packaging is great. satisfied with the product. thank. the power supply will come and write in more detail. and you need to purchase the battery separately.
Are there any plans for this kind of unit to be available in a higher current? I love the DPS5020 and have been considering it, but I really like the interface on the RD6006, along with the case to hold it all with the PSU.
The high quality of Riden products and customer care is visible even in the product packaging! In my opinion, this is an advanced and inexpensive Power Supply for a home laboratory!
