New Announcement: ACEBEAM L17 "The World's Longest Throw 1x18650 Tactical Flashlight"
1. The Longest beam throw model aims at the hunting and tactical&law enforcement
2. 3 version LEDs for option: OSRAM White, Green and Red light
3. The L17 is compatible with Remote Control Switch L16 (ARPS-R05)
4. Powered by 1x18650 battery (Recommend ARC18650H-310A with Built-in USB Port)
5. 5 brightness levels and 1 special Strobe available
6. Compact, Lightweight and extremely Durable
Click and get more information here: L17 Tactical Flashlight|AceBeam® Official Store | Flashlights, Tactical Lights
Looks good, can you tell us which is the emitter in the white version?
And what does the turbo mode steps down to?
TIR? Unusual choice for a thrower.
BTW, Acebeam, you’re violating the BLF rule that states:
1400lm? Which Osram LED model is it? Doesnt seem possible to achieve 1400 lumens
Probably Osram CSLPM1.TG 2mm
“The World’s Longest Throw 1x18650 Tactical Flashlight”
Quite a claim there, care to prove it? You wouldn’t even be allowed to put that claim in the UK market unless you could prove without doubt it was true. I doubt that is possible.
Good point. There is some competition out there. The Maxtoch Archer Osram has a tactical form and Eagtac has one or more tacticals with Osram.
Whatever, I going to buy this, big claims or not. I am enjoying my E10 and Acebeam are quoting longer throw on this light. I like the idea of having this size and throw with a 3700 mAh Panny in there for longevity.
3700 mAh? Is it a mistake or did I miss some new cell on the market?
The Olight MX2 had a larger head so was not as convenient to carry. 810m? With the newer led although it’s quite cold.
I think the low price is due to the competition from Emisar and Lumintop.
This is best result I got when analysing 4 new Sanyo NCR18650GA’s
in a Xtar Dragon VP4 Plus. The other 3 were around 3450 - 3600mAh. Do you think that’s inaccurate? Could be…
I don’t know but I would be surprised if this was real.
What I could imagine is a customized 18650 cell with a slightly larger volume, i.e. larger diameter. Molicel M50A for instance does not match the standard size of a 21700 battery. It's more likely a "22700" battery.
Bold claim. Is that a small optic in there? Maybe a light recycler? It’s Acebeam so who knows.
It’s OSRAM.
Turbo: 1400 lumens; 160801cd; 802 meters; 1 hours 15 minutes
E10 PK L17
L17 with Beolit 17, is that pun intended?
Hard to tell the difference when one is ponting further than the other.
Do both lights share the same TIR optics?
Yes, You are correct.
