It probably doesn’t have a factory reset function… but if it does, it would be accessed by a “13H” action. In other words, click the button 13 times, but hold the last one for a few seconds.
But it probably doesn’t have that, because the factory reset function was added a month or two after the FW3A was launched, and Lumintop rejected the firmware updates I sent.
The 13 clicks thing is unique for the FW lights, right? The “hold the button while connecting power” is for more conventional e-switch lights, right? I’m always getting these mixed up. Lol
The 13H thing is currently only used on lights with tail e-switches… because on those, it’s usually impossible to hold the button while connecting power. For the FW3A in particular, power is connected long before the button.
I’ve been thinking of adding 13H as a standard thing on all lights though, for consistency.
I have read thru the majority of this thread I have three FW3a’s I have taken them all apart and put them together again and they all work. Today I received a 18350 copper tube and inner tube the from Neal and I cannot get it to work. With any of the switches. The o ring is in place I put on the tail cap first tight and then screw on the head sometimes I get the connection flash others not. The switches all work on each other but not with the short copper tube. I dont know what to try next any ideas ?
Chris
I don’t know much about the short copper tubes but you might want to verify they are designed to work with your particular tail switches. There was a design change when they added a retaining ring to hold the switch assembly in place. They had to alter the battery tube threads in order to get them to work.
You can test if your tail switches are making contact. Check this vid at the 2 min mark.
Still no luck both short tubes I have,al and cu look identical. The al one works the cu not. Dimensions are within .001 of each other in length and all.
Chris
I have a short alu tube I could never get to work right. Maybe due to tailswitch change—I’ll have to get it out and try it again with various iterations of tail switches.
The clip is not on it. The threads are the same. After fiddling with it some more I have come to the conclusion that the inner tube is not making good contact with the switch ring in the head, I can’t make it longer so I am sol I guess.
C
thanks for the help guys.
You can make the inner tube longer by making the outer tube shorter. Did you test for continuity with the head removed like in the video I showed? I’m guessing that the switch does work and that’s why you’re thinking the inner tube not making contact with the driver ring? Assuming you have a little bit of a gap between the head and the battery tube when they are fully tightened you should be able to remove a little of the battery tube length on the head side.
Get you some sandpaper that’s about 400 to 600 grit and put it on a flat surface and then you can hold the battery tube on top of it and slide it back and forth making sure to rotate the tube every now and then so that it takes material off evenly.
