Shame to see that. I had seen a different review where the reviewer stated they didn’t see any by eye or with the camera they had. Maybe it won’t be bad PWM?
Oh it’s pretty bad on low, gets better on medium, can’t see it on high. I don’t see PWM unless it’s super slow or I turn my head quickly. Not annoying enough for me to stay away from it.
My daughter has some of those RGB light strips in her room with the slowest PWM I’ve ever seen. If I can see it, it’s horrible.
It is fairly easy to get apart and mod though. It’s put together kinda haphazardly. Sorta like put all the parts in and smoosh them together. For the real PWM sensitive people, consider it a good host. I got one with a 219b in it and another with sst-20. The other ones are still stock sitting in a drawer. Again the PWM doesn’t bother me so I had no need to swap in a driver. A ultratac A1 driver might be a good choice. Not certain on fitment issues. $19 for a nice stainless host, I think, is still pretty reasonable.
yes, it does look like a nice host
other nice hosts with PWM include the AA Ti Tool, and the AA Thrunite T10T… they cost more but also weigh less than Stainless… choices are good… enjoy!
Seems like most are passing on this light on account of the PWM issue, but when I went to check my tracking number today I noticed some new stuff on the site. In addition to the Cree and Nichia, this light now lists the following emitter options that AFAIK weren’t there before:
Got mine today, didn’t have any previously but it seems like a decent light.
I spent far too much time figuring out the tail switch, pretty clever design. I couldn’t easily budge the pill on the head side though. I’m guessing I can use the holes the LED wires go through to leverage the pill out?
The pill looks a bit like a (recessed) washer with threads for the head protruding on one side and threads for the body protruding on the other side. I guess you removed the head-part. It’s a bit of roulette which part come off first, head or body. If things go as planned, it should be the body part. Just as seen in the thirf picture of the OP. So I use a tiny drop of glue on the head end of the pill, in the hope the other part comes off first.
The pill is not (eg. should not be) screwed in with a lot of force, it is the side you put a new battery in. So it should come loose by using a rubber strap. Or by using rubber (garden) gloves.
Guess what appeared this morning in my door?
Yes!! The SS light
My perspective: it is small (not the smaller AA, though, if compared to the DQG Slim Ti), it is heavy (heavier that other AA lights and even some 16340s, but…it is Stainless Steel), it is very well done (no apparent flaws on machining anywhere), it is robust (really robust, what makes it ideal for EDC), the beam is pretty nice ( mine has a vey good Neutral White, I chose the Nichia 219B SW45k D220 R9080 4500K). The UI is straight forward, 3 modes without memory, no complains, and I just didn’t check for the PWM or driver whining. Like
Also, flat top cells such as the Sanyo UR14500P may not do contact with the driver because of the retaining ring! Button top cells work.
About chemistry, I tried the Lumintop 14500 Li-Ion cell and it lit up and immediately shut down again. I thought I had fried the driver, but then I tried an AA alkaline and had no problems. So, using Li-Ion cells may bring some issues!
I am really happy that Fireflies did these lights again!
Yup, you are correct, the one on the right side is a Lumintop Tool TI (AAA/10440, modded by CRX)!
The line is (left to right):
1- Nitefox ES10K (Stainless Steel, AA/14500)
2- hc-lights SS AAA (Stainless Steel, AAA/10440, similar to the BLF 348)
3- Amutorch S3 (Stainless Steel, AA/14500)
4- FireFlies SS AA
5- DQG AA Slim Ti (Titanium alloy, AA/14500)
6- Lumintop Tool Ti (Titanium, AAA/10440, modded by CRX)
