It has a forward clicky, so yes, momentary is possible but this will also switch modes. I would have been okay with single mode - as for throwers this is basically all I need.
I would love to have the option of choosing between 1-mode and 2-mode by a series of rapid clicks (20+) or a similar method.
Low can be used 5ft in front of you, but the hotspot is very small and still kinda intense, thus I would rather pick my D4 for that task.
Nice… Not to hot of a flashlight or hard to find any info on it I should say… Not a single Youtube vid… but I like my Jetbeams… Never had one fail! Had many Nitecores take a crap… Thanks for sharing!
The OP claims it outthrows his imalent R90C which is rated at 1679m but one bg reviews say it’s outperformed by even the T7L 1100m. What if the first few samples performed better for some reason? The rating does seem a lot higher than similarly sized LEP lights so it could just be overrated. LEPs I guess are hard to focus cause sometimes they perform much better than the rating . Some ppl measured 2.2
the weather was nice to me...
at each distance i took 3 values (15 sec) - the highest made it into the list below
started with full cells (vapcell 5000mAh) both down to 4.07V at the end
reading
cd@1m
throw
M2S @ 5m
16890
422250
1300
M2S @ 10m
4240
424000
1302
M2S @ 15m
1779
400275
1265
M2S @ 20m
1050
420000
1296
M2S @ 25m
680
425000
1304
M2S @ 30m
444
399600
1264
W3 Pro @ 5m
14790
369750
1216
W3 Pro @ 10m
3610
361000
1202
W3 Pro @ 15m
1660
373500
1222
W3 Pro @ 20m
889
355600
1193
W3 Pro @ 25m
587
366875
1211
W3 Pro @ 30m
382
343800
1173
left: jetbeam M2S / right: Weltool W3 Pro
[/quote]
Thank you. So my measurement are comparable to yours. I wonder if both of us have a faulty one or if this normal. I hope more people can measure theirs and chime in to triple check.
I was just checking the Chinese manual, and it looks like the manual says: 250,000 cd.. but the box says 800,000 cd. Something is misleading here.
For 250,000 I would have never bought it!
