Hi everyone, just got my LT1 and I’m loving it. Thanks to everyone involved in the process.
I’m working on a detachable base that doubles as a bumper. This is the first version as I tweak with the tolerances (I have a very cheap printer that isn’t set up very well). It retains access to the tripod hole. I’m thinking of making it click into the ridges instead of being help in by friction. I’ll possibly do some different types of bases as well. I’m an amateur so we will see how it turns out.
This would also work well printed in TPU for the grip and anti-shock properties, but I do not have any TPU filament to test. Once I tidy things up I will share the file here
My JBL case is coming in the mail (I got one without the extra pocket at the top of the lantern). I’d love to test it for you but it’s coming from China so it will take a very long time :cry:
Sorry if this has been asked before. I have seen the post from ToyKeeper saying there is no commercially available firmware update kit. Is there a guide on what we need to convert and use the D4V2 update kit on the LT1, since the pinout is different?
I brought a (thrift store… Joby GorillaPod Original Tripod for point and shoot camera,it works perfectly at the base or side screw ,Need to pick some wrist bands to better protection,I agree orange rings always slides out ,every time I pop it out of my LTI case(JBL speaker case)
Should be as easy fit diameter wise. It looks smaller than the head.
If it doesn’t add too much length, it should be OK while attached to the lamp.
In the top? Depends on how much room the straps take up.
All the Best,
Jeff
Any updates on the accessories? I would love to try out the side reflector (foil covered license plate or something similar) as I found that in most cases, I use the light just from one direction, to read a book for example, so the light shining to the other directions is wasted.
