26800 Lithium-ion battery
Noice!
I’ll be looking to see if any of my 26650 lights have “too big” springs. :laughing:
I’ve seen the battery before and I really liked it. I asked a couple manufacturers to offer longer tubes…without success.
Nice to see a manufacturer that tried, though this is not my kind of light.
I haven’t thought about trying to fit it in a 26650 light. :wink:
Personally would love to have a quad tube for my L6 but alas
I think ya would have to remove one of the springs at one end and replace it with a brass standoff or something.
I’ll see how much room is in my various 26650 lights.
Seems I remember the SP70 had a long tube.
All the Best,
Jeff
Sounds like a great battery for my needs.
Stupid question now. Is it possible this size battery will become popular and widely available or will it fade into obscurity? The battery world seems to be “driven” by EV manufacturers, so does anyone have inside info or a crystal ball to assess the chances? And then there is the charger issue…. any thoughts or guesses?
Nealsgadgets also list 21700 batteries as being usable in that light. I have not got a single charger that could charge a battery that long, so that would be a deal breaker for me. I guess I could get one of those olight chargers with magnetic positive and negative ends, but still, as many 21700 batteries as I have, I would just use them. you could also rig up a piece of steel bar 26mm diamater and 15mm long on the negative side to allow use of 26650 batteries. I just never have liked batteries of unusual size. In spite of what Olight would have you believe, a standard 21700 protected button top battery will work fin in my seeker 2 pro turned with the negative closest to the head, it just can’t be charged inside the light. The orbtronics batteries work well. No need to pay over twice as much for the Olight modified batteries just to have a spare.
I’ve got some 26700 that fix everything but Fivemega host. 26800 fit nothing. It comes close in the Convoy M3 but it will need some milling.
I don’t think there’s significant future for this size. No big cell manufacturers make it which means that few flashlight manufacturers care.
This is unfortunate though, 26800 is quite an ergonomic size.
Thanks for the reply. I think I’ll pass on this one and stick to a few popular sizes.
I received the Nightwatch NSX4 XHP50.2 K4 from Nealsgadgets today. It came with a Yonii C2000 battery charger that holds up to 86mm batteries. IMG-9577 hosted at ImgBB — ImgBB IMG-9579 hosted at ImgBB — ImgBB
No idea of this chargers quality.
Good to see that I am not the only one that started checking my lights and thinking about “Will it fit?”
Thanks for the pics. I am also getting that light through SkyLumen. I asked him about the charger that comes with it. He said single cell and charges at 2 Amps. No doubt the same one you have.
When I google YONII C2000 nothing comes up. Before I knew the name that you provided I decided that I better get Two of these Folomov magnetic chargers. Only charge at 1Amp , but good to have others in case YONII is not reliable and for the ability to charge more batteries.
https://www.batteryjunction.com/folomov-a1-usb-liion-charging-cable.html?gclid=Cj0KCQjw3s_4BRDPARIsAJsyoLOqrNTjbEvif9GFA_tdPKP0L_gmc5mjSK-3qpn8-Drqu026f2ZNM40aAkAxEALw_wcB
Got the 26800 to fit a FT03 with De-lensed 90.2… copper contact on driver, bored out copper rings and driver retainer, to space out battery tube, flat laying (when totally compressed) alloy gold plated tail cap spring… 4.21v 22.7amps 5200lumen off the T/A maukka lumen tube.
Purchased 4 of the QB26800’s… thinking about maybe making a couple custom tubes for other lights I have…it is a really good performing battery so far…
Wow. A dream walking light.
Now this would make one great BFL build that I would buy! What a cell and the price is amazing!
Liking my 26800QB Powered…UTORCH 3x50.2 3v……… :smiley:
@texas shooter
Thanks for the link (‘alofthobbies’). Unfortunately, the shipping of $12.50 USD to Canada breaks the bank.
Had purchased a NA40SE and shortly after receiving saw this add-on: an extension tube with this similarly sized battery. But cells not within the OEM device are not shipped here. Would have liked the form factor plus an increased output (6500+ lm).
Backstory; Neal (Gadgets) has this but at 98 mm length. The extension tube may ‘lego’ to some other lights? [link in pic]
What !? :open_mouth: :exclamation:
Did you paint the tube? Put a wrapper over the tube? Photoshop?
No…the head was opened up with minimal clearance, like a reamed fit it is tight to the battery O.D. and a ring groove machined into the neck, a circlip ring inside the head engages the ring groove on the battery to hold in place that is the actual battery (with out the wrapper) plugged into the C8F head… been working/testing and working on a couple idea’s…
I once told HKJ to review the Yonii Q1, which I also bought. He mispelled the name, though. Bad stuff (the charger).
Sat, 08/22/2020 - 15:31
