That’s an unpopular opinion here but I agree. Less of a toy and more practical for me. Where I am, ambient light is good enough to replace moonlight most of the time. But when we really need the light, and without a bigger flashlight in hand, a 2 mode high and moonlight flashlight will effectively become single high mode flashlight. With less than 45 minutes workability. As thought batteries won’t be fully charged everyday.
Maybe I should explain: Moon preserves nightvision. But existing twisties cannot be reliably activated in moon mode. Don’t know how many have used one on a regular basis - I did, and I know mode jumping fairly well by bouncing contacts. A good debouncing algorithm should be used (a 10th of a second or so), and the C01S has none. If you need your nightvision and the light jumps to high mode, you’re done for the next minute or two.
You used a twisty light, usually starting on Moonlight, but it accidentally turned on with High mode because it interpreted one twist as two twists (which effectively cycled to High mode)?
Haven’t experience that. Since I don’t use twisties regularly. Usually used a tailswitched light.
It seems that not many share my view of usefulness of true middle mode. Sublumen or moonlight won’t show you creepy crawlies. But good for reading something in a jiffy.
For me, I found out that when I want a moonlight mode, to preserve my nightvision, I have other alternative, it’s never a pressing sitauation that may save you from something. It’s more of a wants and enjoyable game type of situation.
Would like that the nice c01r three mode trickle down to the c01s series.
Anyway I’m waiting for c01s to arrive to see if the 3 lm low mode is useful other than helping you goes to the toilet. Which I never needed. Hope that they will at least be better than smartphone camera light in helping you navigate safely if you’re ever in pressing situation.
Got the new colors today (except the “new” blue, I already have 2 blues so maybe I’ll get the new one later). The new colors are the 4 on the right. I’m quite fond of the green and brown ones
Honestly it feels more grippy than the original to me. but here’s a macro shot to do the talking. Looks to me to be somewhat similar knurling, but the macro makes it look deeper, which makes sense as it feels grippier. I personally think it feels nice, but I think both lights do.
Thanks, I like the head grippy but i’ll end up sanding down the body (again) it looks like. The blasted one was fine but raw was too much for my delicate model hands.
If the head isn’t sufficiently unscrewed when trying to turn it off, a little side pressure in the pocket can blink the light — then turning it on intentionally makes it come on high. Needs plenty of threads so it’s safe to twist off OFF without having it fall apart.
