Varbos provided a link. I have not ordered it, but I could. Apparently.
Is it really an e-switch? I have not found this information.
I didn’t knew this. Took a second look at the mechanics of the KR1 and am still puzzled what a potential problem could be. Head and tailcap are not even especially tightend and it still works. This construction with springs for battery and inner tube at least seems safe. Maybe dirt/grease on the inner tube could prevent functioning?
The new UI looks much better than before, but I would prefer moonligh to not be in a different group (what’s the point ?), it’s the same for the thrunite T1, you can turn on directly on moonlight but if you want to go to low, well you can’t, not directly at least, you have to turn off, then single clic which bring you to the last mode used in the main group and then cycle to low and potentially blind you in the process.
Manker is quite well-known brand among flashlight enthusiasts, but they don’t have a good opinion. The main reason is the lack of manufacturer support and problems with the warranty. Although the flashlights are imho a very good quality, problems often do arise.
Another reason is their (old?) UI. Reproduced in many flashlights and almost always criticized. Nobody likes long click for on/off. The new one looks much better.
See this thread where people complain about Manker. I have a few of their flashlights, but I don’t use them often, so I won’t comment on that. Although I had no problems with them.
Good point. I don’t understand why they have to split the moonlight. All the other manufacturers have moonlight with the main modes. I wish Manker fix this in their next version. Otherwise the new UI is perfect.
The “perfect” UI is hard to obtain by everyone’s standards. But to be fair to Manker, this looks pretty darn close as far as UI’s are concerned. I’m worried a little bit about mode spacing, but we’ll see. This is the first Manker (along with the MC13) that I’ve been interested in in a while.
