Ok guys… another quick teardown. As it turns out, there is NO GLUE. What I saw as glue was actually thermal paste between the board and the pill. The white clip can carefully be removed. After doing so, the board comes right off. That entire area that is covered in silkscreen is a big thermal area. So while this isn’t a MCPCB, it has a big thermal path right to the pill and is covered in thermal paste. For 100 lumens, that seems sufficient. LED swaps would be difficult though… perhaps with hot air reflow.
EDIT: looks like the IC is the tried and true PAM2803
The resistor says 043 (underlined). If I understand correctly, that would mean R043 = 0.043 Ohms. But for a PAM2803, that would mean a LED current of 2.2A which certainly isn’t right. If it were a 0.43 Ohm resistor, that would make sense… translating to an LED current of 220 mA.
Thanks for the “deconstruction” gchart! Seems like the original setup is made to “stay as it is” ! And with a nice led, I guess it is not bad at all
Nice light!
Hey gchart, is that the real color Red? Look more like tan/brown to me. The color does not look like Red on their Amazon listing or website.
Anw nice color options though.
Sorry, I messed with my camera settings in my initial images and I’m colorblind so I have no idea how accurate the colors are.
Here’s one I just took. Outdoors (obviously) under a direct noon sun sitting next to some ripe tomatoes. Default image settings on my Pixel 3. How’s this look?
I hope I never lose this one in the grass because I’ll never be able to find it
Cactus vs. red C01 (same anodization as C01R): undecided. The cactus reflected a lot of red light, the red flashlight reflected surprisingly little red light.
Real tiny AAA twisty!
I just ordered one slate blue NW from AE to see how it goes. 8.65 euros shipped looks like a good deal.
Thanks for pointing it out.
Mine comes today from Amazon. Curious if the TIR opening is big enough for a larger LED but I assume it’s the same dimensions as Sofirn one with tiny opening.
Will probably try to reflow whole board with components in place later tonight
