Thank you for your informative review of this atypical flashlight. It is noteworthy that you measured the amount of lumens on turbo that you indicate. I got two of these red hot little screamers. I think this is the most powerful light in its size class. Also, it has normal modes for normal runtime, too. I use mine to very briefly powerfully illuminate a wide close area, to quickly identify smaller points of concern to further illuminate in normal mode. Thanks again!
Does MS03 require included battery or any other high current 21700 can be used? Thanks for the review.
Thanks for the review. Looks like the stepdown on High and Turbo based is based on a timer not thermal.
great review, thanks!
I have an Imalent and like it a lot. high quality product.
wow, suprprised that Imalent managed to make flat stabilization this time.
is that time or thermal regulation?
does cooling affect med2?
The included cell is a bit longer that normal unprotected 21700 cells.
If you want to use unprotected cells, you will most likely need to add a dub of solder in the positive terminal of the battery (or maybe a magnet in the back side).
Indeed a flat stabilization! As for your second question, I’ll have to investigate a bit more and come back to you
Edit: Imalent informed me that there is a pending Giveaway for 3 x MS06. I’ve added the details at the bottom of #1 post.
I want to win a MS06!
Thanks for the Giveaway. I have a RT70 and would really like to try out a MS06
That really would be something else. Thanks in advance.
Thanks for the GAW
Guys, I think you’ve misunderstood the description of the giveaway
In order to enter the giveaway, you need to go to www.imalentstore.com and click on the ‘chat with us’ buttton.
This will allow you to chat directly with the customer support, and that’s where you should be submitting your entry
Well, it was fun while it lasted.
If something is too good to be true, it probably is not …
Thank you for filling in the blank spaces.
EDIT: I went to their website and read about liking & sharing.
Not sure if giving away is indeed actually giving away.
Let’s just say it’s not my cuppa tea.
So all we have to type is “I want to win a MS06!” in that chat box correct? no handing over of personal details etc. How will they know how to contact us if we were to win then?
Thank @bilakos10, I try contact them on the chat but no one reply.
Here is the post of the GAW: IMALENT Lumen Master-MS06 Selling Time and Product features.
No idea how is this GAW going to work. :person_facepalming: :person_facepalming: :person_facepalming:
Is that correct? thanks for your review, it looks cute, wish I could get the honor and luck to win this giveaway.
If no one is going to copy this atypical light, and if this is not a copy of a pre-existing light, I want to buy a MS06.
Great review! I bought this light based on this review and the light output is truly incredible
How do you attach the wrist lanyard? I don’t see a little hole on the end to use. There are some holes on the heat fins near the front but it’s uncomfortable to do it that way. Lanyard isn’t long enough for me to have it on my wrist and hold the light normally
Thanks
For everyone who wants to take part in the GAW, follow the link posted above and comment in the comment section. your name and email is given to Imalent and they may contact you if are a lucky winner.
Almost NINE months have passed since OP. Has anybody heard about someone winning a light after: “Send us a “I want to win a MS06!” by Contacting IMALENT online customer service and maybe win 1 of 3 MS06 we giveaway! “?
