Here is my attempt a capturing a C01R moonlight beam on a white wall. There is a distinct irregular spot in the center. It may be hard to see on your computer or cell phone. I believe in the C01R thread someone was asking about a defect in the TIR. I think it is just a characteristic of the TIR optic used. I don’t mind too much for the C01R considering the cost and because you typically can’t see it in normal use. However if the same TIR is used for white light I am guessing some of the CRI babies around here will complain about it. Worth considering an upgrade for the E21a model?
Very interested - have SST-20 on the way, but I’d easily buy another in 4500k (4000-4500k is my sweet spot). A really low firefly/moonlight mode would be nice but is we’re going with a true “budget” theme then it should be centered around the emitter without changing too much else up (L to H is a must).
Your suggestions are in line with the observations of Djozz and Unheard posted on the C01R thread. A microlensed or frosted lens will probably be mandatory for the Nichia E21A emitter to eradicate the tintshift. I will talk to Barry about the proper characteristics and point Sofirn to Clemence's thread to find a suitable optic. If all works out this optic may also become available as a spare part or accessory for using with C01R or C01S with SST-20. Let's keep our fingers crossed. :-)
I have now started with the interest list. Please check the OP and let me know if you see anything to change i.a.w. your requested quantity and tint favor. I will regularly update the list.
Unfortunately, I began too late to ask explicitely for the desired quantity and tint versions. :FACEPALM: So, please excuse if I have put you down for the wrong quantity or tint but I tried to catch the information as best as possible according to your answers. If no quantity or exact tint was expressed I have counted your vote with only one piece and no tint preference. It is very likely that some of you may be interested in more than only one tint. If I have forgotten anybody to include on the list, please let me know so I can update the list. Thanks a lot!
Agro, ch1ir:
I have put you down on list even though you clearly expressed this light is only interesting to you if it works with 10440 cells. For the moment, I cannot tell you if that is going to happen. Please let me know if you want me to change your entries on the list.
