(seller: if you are charging battery, you had better to use the battery charging terminal, I see the settings, 4.2V is peak voltage for one 18650 battery)
the packaging is great. satisfied with the product. thank. the power supply will come and write in more detail. and you need to purchase the battery separately.
Are there any plans for this kind of unit to be available in a higher current? I love the DPS5020 and have been considering it, but I really like the interface on the RD6006, along with the case to hold it all with the PSU.
The high quality of Riden products and customer care is visible even in the product packaging! In my opinion, this is an advanced and inexpensive Power Supply for a home laboratory!
On the way for almost two months. The packaging is excellent, the mail will not break. The IIP itself is very advanced. Already at work. Thank you seller!
Initial impressions of the RD6012 are good. Took less than 30 minutes to get it running, taking my time and being careful. It is probably the best power supply you can get in the price range
Delivery from Moscow(RU warehouse) to St. Petersburg 3 days by courier to the door. the firmware is updated, the USB and wifi connection is working. the package matches the description. no comments.
