✌ FREEME - MEOTE FM1 LH351D (CRI90+) / XP-L HI (4980lm) / SST20 Anduril 18650 EDC Flashlight - ALIVE!
767 posts / 0 new
freeme
freeme's picture
Last seen: 2 hours 42 min ago
It could be due to the clear coat just like mine. Try to polish the surface for a little first?
Quote:
Took a closer look at my light today, and just noticed the copper has some machining defects. Anyone else have similar issues?
1thedeals.comyoutubeAstroluxNealsgadgetsolight
SlvrDragon50
Don’t think so. It is quite deep. If there is clear coat then polishing will remove the clear coat and make the copper tarnish very quickly.
pinkpanda3310
pinkpanda3310's picture
Last seen: 15 hours 5 min ago
After being offered a refund on a number of occasions i think i can write this off as a complete loss. Banggood CS is just lip service now.
mortuus
mortuus's picture
Last seen: 7 hours 32 min ago
if light never arrived u should get money back, i got money back on my light that arrived but had issues… try again maybe?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
TheAuditor
Last seen: 8 hours 8 min ago
I wonder if there will be a version two. It’s gone a bit quiet.
Bonum commune communitatis.
Yarp.
gchart
gchart's picture
Last seen: 1 day 29 min ago
Mine arrived today (thanks for the GAW, MascaratumB!!)
I’ve only played with it for like 1 minute but it seems to be in good order so far. Bright, connection is good after I tightened it (it did flicker at first), beam pattern is fine in mine (no donut hole, LH351D version). The noisy button is kinda annoying but nothing I can’t live with (or honestly I can probably find that with a new e-switch or something). I’ll give it a good run through tonight when it gets dark.
MascaratumB
MascaratumB's picture
Last seen: 3 hours 52 min ago
!{width:600px; max-width:75%}https://i.imgur.com/dADmIqm.jpg!
Eheh, finally Wink
First order – 14th April ! Arrival – 24th July!
I hope it is one of the non-faulty lights Wink Evil
Congrats again gchart Thumbs Up
freeme
freeme's picture
New sample has arrived today. I have not been brief on the changes yet but i will take my time to play with it for the next couple of days.
TheAuditor wrote:
I wonder if there will be a version two. It's gone a bit quiet.
pol77
Last seen: 3 min 37 sec ago
Are we talking about the exact same design + an attempt to address the issues?
d_t_a
Last seen: 21 hours 4 min ago
I hope they could correct the “beam artifacts” issues for the Meote FM1 with XPL-Hi and SST20 LEDs (the LH351D is acceptable beam, other than lower brightness than expected). The XPL-Hi and SST20 have also lower brightness than expected and with noticeable beam artifacts. If they change the optic in the updated versions, I expect that they can ship out the replaced good optic for those who purchased the early batch FM1 with the poor beam artifacts on SST20 and XPL-Hi LED versions.
Nicolicous
Nicolicous's picture
Last seen: 9 months 3 days ago
Hope we can buy spare parts to fix the older version.
Nico -.-
08CivicSi
Last seen: 8 months 4 days ago
any updates?
freeme
freeme's picture
There are something i need to reconfirm with MEOTE before i release any statements.
08CivicSi wrote:
any updates?
SlvrDragon50
Hmm, anyone else having issues with the light being REALLY sensitive to bumps? A slight tap on the tail makes my light turn off.
d_t_a
This issue seems a bit common for flashlights that don’t use springs on both ends of the battery tube (head & tail). The Meote uses a button on the positive side, thus a bump may disconnect (a spring will usually not have this issue) — however I think having a button may have some advantages (lower resistance for current to pass?)
SlvrDragon50
Should a strong spring not be enough to resolve this? Or will it always be an issue?
