You made it sound like an electrical problem.
“I thought any 18650 charger would charge an unprotected 21700 cell.”
They technically all can, since a 21700 is the same lithium technology and voltage as an 18650.
The only issue is physical compatibility, which is what went wrong here.
If a charger can fit the extra length of a 21700, or if you use wires and an external battery holder, there is no problem.
A wiser option would be not jamming cells into a charger so hard that you break through the wrap.
Also using higher quality batteries such as samsung or LG will also come with more durable insulation wraps.
Or the wrap is faulty from shopping and you don’t see… it happen
Before put battery check always technical spec on original site.
For example, I don’t know why but Xtar Vp4 Drugon Plus don’t charge 21700 protected
but charge 21700 unprotected.
Probably what happened. Either the insulation was already damage or it got damaged by inserting it in the charger. (not saying that you were careless or something like that!)
Either way, this is a great lesson to all of us to really be careful when handling a cell. And to not put any other cells in a charger that's not designed for them.
Thank god it didn't get out of hand and that you are fine!
Well, it does not suddenly make a short.
Are you 100% sure your charger is ok?
Are you 100% sure your cell was ok?
If so, it must be a human error as described above.
Probably by damaging the wrapping by trying to fit it in a charger which is not suited for that size cell.
The ring on top of the cell is were most wraps tear up first, IMO. those tears can be really thin and invisible; when the cell was inserted the charging contact accidentally connected BAT+ and the cell body.
I’m not an expert on battery chargers nor an electrical engineer but how is the charger and all its built in protections supposed to work if it’s not plugged in?
Some people put the cells in first and would then connect the charger. In fact, in the RC hobby many people do it this way. hobby chargers can be finicky at times…
I would rather be elsewhere when switching on the charger rather than put the cell in when already powered on… I mean… normally nothing happens… but what if?! I like my face the way it is.
Like I said I’m no expert but I’m pretty sure the chip in your charger is not powered by putting your batteries in to charge so how can it work? It’s not like a flashlight where the chip is powered by the battery. So I’m assuming here but you basically put in a very powerful battery in and completed the circuit with no control and it dumped all that power with no regulation and nowhere to go, unlike when it’s plugged in.
With sprung bay chargers like the one used, if there is no clearance of the cell positive and the charger positive when inserting the cell then there is a risk of damaging the wrap when inserting.
You should use the cell to push the sprung charger contact down, lay the cell flat in it’s bay then it should slide up to make contact.
Don’t push them directly in flat as you will catch the cell wrapper on the charger contact and wear or a direct rip may occur in time.
Cell wrappers are very thin plastic and easily damaged especially on corners when pressing over other hard objects like metal with protrusions.
If you do need to cram one of the larger cells into a charger then use a thin sheet of tough plastic etc to hold in the bay over the charger positive contact while inserting the cell to prevent wrapper damage. Once the cell is flat in the bay pull the plastic sheet out while holding the cell flat.
Also check your cells wrap from time to time to make sure it is intact, chargers with dimple protrusions on the contacts like the one pictured are better at poking through any holes and welding, I prefer contacts that are flat.
rewrap the cell and move on.
that charger is too tight for a 21700.
it tore the wrapper with the 2 contacts due to the pressure of forcing it in.
at least you got it out.
super high drain cells like the p42 get pissed off very quickly when shorted.
