[Review] Imalent MS03 ( 3 x XHP70.2 - 21700 ) - 13000 Lumen Single Cell Monster + MS06 Giveway from Imalent
24 posts / 0 new
bilakos10
bilakos10's picture
Last seen: 18 hours 27 min ago
The flashlight was sent to me by Imalent for review.
Here's the product's link: Imalent MS03
Also a link to an upcoming beast: Imalent MS06
The MS03 comes in a very elegant box, typical of Imalent's packaging quality.
The flashlight is placed inside foam for added protection, while the accessories are stored is a separate compartment.
Other than the flashlight, one finds the following accessories included in the box:
Carrying pouch, adjustable wrist lanyard, type-C charging cable, 2 x replacement o-rings, manual leaflet
The carrying case is made out of nylon.
It's quite tough and its texture kinda resembles the feel of a firehose.
The flashlight is secured inside the case via velcro.
The back side of the case has a plastic loop as well a velcro-secured belt loop.
The MS03 comes with a black-matte anodization and an aggressive overall look.
It's operated via an metal e-switch mounted in the upper part of the head.
There's also an indicator LED placed right down the e-switch.
While turned-on, the LED informs the user about the battery's charge level.
The head comes with some thick, deep heatsinking grooves which help in heat dissipation, while the rest of the body keeps a relatively minimal design.
The head comes with a slim, flat bezel.
The three XHP70.2 emitters are mounted inside the smooth reflector and are perfectly centered.
Being completely flat, the tail allows the flashlight to tail-stand.
The battery-tube is glued to the head, so only the tailacap is removable.
The threads are very cleanly-cut and came pre-lubed.
Looking down the battery tube, we can see that Imalent has chosen to use a brass tab as the positive terminal.
Following Imalent's tradition, the MS03 also comes with an 21700 4000mAh high drain cell.
The positive side of the cell has a plastic gasket which ensures that the battery stays always fully aligned with the drivers positive contact.
The battery also has built-in recharge circuitry via a TypeC interface.
Once plugged in, the LED at the top of the cell will shine in order to indicate the charge's state.
User Inteface
Here's all the actions supported by the flashlight's firmware.
Turn on/off: Single press.
Mode cycle: Long press ( Low > Middle Low > Middle 1 > Middle 2 > High > Turbo > Low > ... )
Turbo: Double press from any mode or off.
Strobe: Double press when in turbo.
Lock / Unlock: Triple press while off.
Indicator Light ON/OFF: Long press (2sec) while off.
It's worth noting that the MS03 comes with Low Voltage Warning set at 3.0V as well as mode memory.
Output
Here's the tailcap current readings and output I recorded using the included Imalent 21700 cell.
As you can see, Turbo pushes an extreme amount of current.
I'm pretty sure the Turbo current would rise a bit more, but I had to left off the terminal leads almost immediately cause they got extremely hot - and I got a nasty burn mark Silly
Of course, the flashlight is able to produce ~12500 lumen of light for short bursts.
Regulation
Here's a output / thermal regulation graph I created.
I collected data in 25 minute runs, but since no visible changes were observed after the 3min mark, I decided to only present the first 10 minutes of each run for
resolution's shake.
What we can see in the graph:
  • Turbo and High are sustained for around 35 seconds. Afterward the flashlight ramps down to ~1800 lumen.
  • Medium2 is sustained for 1:45 min. Similarly with the upper modes, the flashlight ramps down to ~1800 lumen.
  • The ramp-down output is fully sustainable and regulated.
  • Medium1 (as well as lower modes) are fully sustainable and regulated.
Beamshots
As you can imagine, the 3 x XHP70.2 + swallow reflector make the MS03 a flood monster.
Update:
Imalent is running the following giveaway:
IMALENT new lumen monster—-MS06! Three 21700 4000 mAh batteries and max output up to 25,000 lumens! Like and Share to celebrate our newest product!
Send us a "I want to win a MS06!" by Contacting IMALENT online customer service and maybe win 1 of 3 MS06 we giveaway!
Edited by: bilakos10 on 07/26/2020 - 04:19
richbuff
Last seen: 3 hours 54 sec ago
Thank you for your informative review of this atypical flashlight. It is noteworthy that you measured the amount of lumens on turbo that you indicate. I got two of these red hot little screamers. I think this is the most powerful light in its size class. Also, it has normal modes for normal runtime, too. I use mine to very briefly powerfully illuminate a wide close area, to quickly identify smaller points of concern to further illuminate in normal mode. Thanks again!
Rev 22:15
g_damian
g_damian's picture
Last seen: 25 min 56 sec ago
Does MS03 require included battery or any other high current 21700 can be used? Thanks for the review.
Rolz
Last seen: 2 days 19 hours ago
Thanks for the review. Looks like the stepdown on High and Turbo based is based on a timer not thermal.
2A
Last seen: 4 months 3 days ago
great review, thanks!
I have an Imalent and like it a lot. high quality product.
Lumeniac
Lumeniac's picture
Last seen: 20 hours 41 min ago
wow, suprprised that Imalent managed to make flat stabilization this time.
is that time or thermal regulation?
does cooling affect med2?
bilakos10
bilakos10's picture
The included cell is a bit longer that normal unprotected 21700 cells.
If you want to use unprotected cells, you will most likely need to add a dub of solder in the positive terminal of the battery (or maybe a magnet in the back side).
bilakos10
bilakos10's picture
Indeed a flat stabilization! As for your second question, I'll have to investigate a bit more and come back to you Smile
Edit: Imalent informed me that there is a pending Giveaway for 3 x MS06. I've added the details at the bottom of #1 post.
Rolz
Thanks for the Giveaway. I have a RT70 and would really like to try out a MS06
Henk4U2
Henk4U2's picture
Last seen: 24 min 18 sec ago
That really would be something else. Thanks in advance.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Yokiamy
Yokiamy's picture
Last seen: 1 day 5 hours ago
Thanks for the GAW
bilakos10
bilakos10's picture
Yokiamy wrote:
I want to win a MS06! Thanks for the GAW
Guys, I think you’ve misunderstood the description of the giveaway Big Smile
In order to enter the giveaway, you need to go to www.imalentstore.com and click on the ‘chat with us’ buttton.
This will allow you to chat directly with the customer support, and that’s where you should be submitting your entry Wink
Henk4U2
Henk4U2's picture
Well, it was fun while it lasted.
If something is too good to be true, it probably is not …
Thank you for filling in the blank spaces.
EDIT: I went to their website and read about liking & sharing.
Not sure if giving away is indeed actually giving away.
Let’s just say it’s not my cuppa tea.
G0OSE
G0OSE's picture
Last seen: 19 hours 53 min ago
So all we have to type is “I want to win a MS06!” in that chat box correct? no handing over of personal details etc. How will they know how to contact us if we were to win then?
Anthony Nguyenn
Anthony Nguyenn's picture
Last seen: 7 months 4 weeks ago
Thank @bilakos10, I try contact them on the chat but no one reply.
Here is the post of the GAW: https://www.imalentstore.com/blogs/news/imalent-lumen-master-ms06-sellin....
No idea how is this GAW going to work. Facepalm Facepalm Facepalm
Lumintop Tool AA 2.0 Nichia + CW| Lumintop Tool AAA | Lumintop EDC 18 6500k| Lumintop EDC 01| Convoy S2+ 7135*8 5000k | Convoy S2 UV Nichia |Massdrop Vega AA NW |BLF A6 NW | Nitecore Tube 2.0 | Sofirn SD 05 | Sofirn 01S 4000k| Klaurus G15 | Klarus HR1 Pro | Thrunite T10T v2 NW| Thrunite T1 Black + OD Green | Thrunite Ti3 CW+ NW| |Rovyvon A3x Nichia | Rovyvon A5x Cree | Rovyvon A23 Nichia | Wuben E19 Nichia | MecArmy SGN 6 | Wowtac BSS V4 | Wowtac W1 | Wowtac H01 | Ultratac A3N Nichia | Wurkkos FC11 |  Wurkkos WK30
Thrunite T2 |
cleo_stary
cleo_stary's picture
Is that correct? thanks for your review, it looks cute, wish I could get the honor and luck to win this giveaway.
Professional and authoritative Acebeam agent with the lowest price.
richbuff
If no one is going to copy this atypical light, and if this is not a copy of a pre-existing light, I want to buy a MS06.
Rev 22:15
Photon Master
Last seen: 6 days 15 hours ago
Great review! I bought this light based on this review and the light output is truly incredible
How do you attach the wrist lanyard? I don’t see a little hole on the end to use. There are some holes on the heat fins near the front but it’s uncomfortable to do it that way. Lanyard isn’t long enough for me to have it on my wrist and hold the light normally
Thanks
2A
For everyone who wants to take part in the GAW, follow the link posted above and comment in the comment section. your name and email is given to Imalent and they may contact you if are a lucky winner.
Majoroverkill
Majoroverkill's picture
Last seen: 5 hours 4 min ago
Doug S.
Henk4U2
Henk4U2's picture
Almost NINE months have passed since OP. Has anybody heard about someone winning a light after: “Send us a “I want to win a MS06!” by Contacting IMALENT online customer service and maybe win 1 of 3 MS06 we giveaway! “?
Yokiamy
Yokiamy's picture
It might be that the promotion was not just for BLF, maybe they used all their social media channels.
Anyway, i don’t miss my MS03, it only did 13000 Lm for 0,1 sec and immediately dropped.
zoulas
zoulas's picture
Last seen: 3 hours 52 min ago
IMHO, a light with three XHP70.2 LED’s needs considerable more mass to produce that output for any usable time. ATR only goes so far. I think this design would do much better in something the size of a Convoy L2.
Tangra
Last seen: 1 day 15 hours ago
Acebeam X45 has great perfomace with 4 x XHP70.2.
5000 lumens constant.
But is much bigger light.
