Not really. It’s a side effect of how the regulator chip works. Technically, 1/150 and 2/150 shouldn’t produce any light at all, because they have the regulator chip set to a level of zero. But it usually allows a small amount of power to pass through even at “zero”, so it’s included as an option because it can provide a nice moon mode.
However, when coming down from a high level to “zero”, it generally overshoots the usual brightness and hits the actual floor… and then slowly settles back to where it should be. There isn’t really a way to fix this in firmware, that I’m aware of. When it doesn’t turn on at a zero level, the chip is operating correctly. If anything in this setup is a bug, it’s that the moon level works at all… because technically, it shouldn’t.
To truly fix it, the driver would need another power channel for the low modes. Like, if the main chip runs at 5 A, the low-mode chip could be like… 80 mA, or about 1/64th as much power. I’m hoping there will be a driver like this eventually, because it would make better low modes, and it would greatly increase the resolution available for brightness.
But that doesn’t exist yet. For now, it’s limited to about 2 lm per step.
That makes sense. The about 2lm low mode of 3/150 is not bad, but the 1/150 is so much better that I am torn and just switched back to it, despite the turbo —> 1/150 issue. I am sure I will move back and forth between them for a while, until I settle.
A way this could be fixed in firmware, I think, is when the floor is set at 1/150 or 2/150 and turbo has been activated from that level, when double clicking from turbo to go back, that could be done in two steps. Step one: turbo —> 3/150, step two: 3/150 to 1/150 (or 2/150). That would solve the problem of turbo to floor.
I cannot think of a way to solve the issue of slow turn on, and it is a bit strange having to let go of the button before the light goes on, for the light to go on at 1/150 and not start ramping before I even see any light, but that is not a huge issue. Unless there is another special check in the firmware and when the light turns on at 1/150, the start of ramping is purposefully delayed.
I think those two checks in the firmware, if they are possible and you can be bothered to implement them, would solve the 1/150 and 2/150 issues and make the modes quite usable.
Any suggestions regarding temperature settings, as asked above?
Does anyone else’s KR4 exhibit flickering at the default low (3/150) setting? It’s not as pronounced as the flickering that happens at 1/150 and 2/150 (though I understand those are officially below spec) but it is still noticeable, especially when the light is stationary for ceiling bounce, etc.
I’ve noticed that, too. I figured it was just a quirk of this driver, though it is a little frustrating. I rarely leave my lights stationary, so I can kind of pretend it isn’t there. I would be interested in TK’s or Hank’s thoughts on this, though.
Sorry, I don’t have anything helpful to add. I only have a late prototype, and it doesn’t flicker at 3/150.
At 1/150 and 2/150 it’s expected to flicker a bit, but at 3/150 or above I haven’t seen it happen. It might be worth cleaning the contacts though, since dirty connections can cause flickering on almost any light.
Do you know what bins are tested in that spreadsheet, there is no mention, all of the CCTs come in 3 luminous flux bins, for example D180, D200, D220.
You can easily use Nichia datasheets basically, at least that is what I have done, and could easily figure out it cannot be anywhere over 2500lm using D220 (220lm-240lm) bin.
Usually datasheets are ignored even if they can prove very useful, especially for the E21 they are pretty good.
The rating is for 700mA . Then you can see what multiplier to use for that 700mA with the graph blow.
Multiple that 220lm by 0.65x and get a relative 143lm * 16pcs = 2288lm
Or the max rage of 240lm by 0.65x and get 156lm *16pcs = 2496lm
So D220 for the 4500K?
That is why I was calculating with D220 ( min 220lm and max 240lm at 700mA) for a 4500K.
5000K is D240 at IOS, so with that the results are 9% higher (increase from min 220lm to min 240lm at 700mA) for the minimum and 8.33% higher for the maximum (increase from max 240lm to max 260lm at 700mA)
It sounds to me like 1x7135 + 5A CC (+ FET?) driver might be a means to achieve this.
I don’t think Loneoceans’ lume1 inductor would fit in the shallow driver cavity of the D4, nor do I know how low that driver can go, but the buck-boost + FET approach seems appealing, too.
A 7135 chip does 350 mA. To make this work well, it would probably need to be significantly smaller… and ideally a nice power-of-two ratio to the higher power channel, like 5A * 1/64 = 78.125 mA.
It uses 10-bit PWM, or 1.95 lm per step. But 1.95 lm is pretty coarse resolution at the bottom end of the ramp… so the idea is to add a second power channel to fix that. It’d make better moon levels, and make the bottom of the ramp smoother instead of having visible steps.
If the second channel used a 7135 chip, it would effectively be an upgrade from 10 bits to ~11.5 bits. It’s not nothing, but it’s not a big upgrade. The effective resolution ends up at about 0.6 lm per step. And the math gets really awkward since it’s not very close to a power of two ratio between the power channels.
So I’m hoping for something smaller with a cleaner ratio.
If the second channel has a power-of-two ratio to the main channel, we can treat it like it’s just extra resolution on the main channel. Like, let’s say we run the main channel in 8-bit mode. It then has 256 steps, and each step is 7.8 lm. Then add a second channel with a 1/64th ratio. Now instead of 8 bits, we basically have 14 bits… and each step is 0.12 lm.
Or it could even go as far as 16 bits… 5A for the main channel and 20mA for the lower channel. This gives 16-bit resolution where each step is 0.03 lm. And it would still run at 16 kHz so there wouldn’t be any visible PWM.
Basically, if 7135 chips or other linear regulators come in a 20mA variety, that would probably be about right.
Output tested using Texas Ace Lumen Tube calibrated with Maukka lights at 2 seconds. Light quality measured using Sekonic C-800-U. The E21A 4500K is just as rosy as the 219B sw45K but with cooler tint. It is a very beautiful tint but I think mixing it with 8x4500K with 8x3500K will result in somewhere near 4300K, which would be more idea. Also the E21A 4500k does not reach 9080.
The E21A 2200K is much rosier than I expected. The 2200K batch that Clemence had was on the BBL. This batch is nicer IMO and exceeded my expectations. Because of the negative duv, it doesn't take long for your eyes to adapt because it doesn't look very yellow. The 2200K tint is similar to a pinkish sunset whereas the E21A 2000K that Clemence sells look like real candle light.
Also pay attention to how much output the bezel kills on the mule lights. Even the color of the bezel (stainless steel vs dark gray) makes a big difference in output. I think Hank should use white mcpcb for the mules to reflect as much light as possible to minimize output loss.
The D4v2 TI with the 16x E21A 2200K is the only light with a loud electronic whining noise on turbo and it smokes as if there's a fire burning. At first I thought it might be moisture that its burning but the smoke doesn't stop and it sure doesn't smell like water. I wonder what is the cause. I don't get this on the KR4 16x E21A 4500K mule or any of the other Hank lights. Anyone have this experience?
D4v2TI 16x E21A Mule Warm White Switch (Aux Light)
(disclaimer: I do not know electronics well so I could be wrong)
A very simple 20mA channel could be no more than a resistor inline with battery and led, switched by a tiny FET. The current (and so the light output levels) would not be truly constant but vary somewhat with battery voltage but maybe that is not such a big deal.
Thanks for all these measurements. The output loss due to the bezel is significant, I did find it weird that the LEDs were packed to the edge of the MCPCB , I think they should be centered with the wires and screws on the edge instead.
The color measurements are not integrated but at the center of the beam right ? E21As do have quite a bit of tint and CCT shift so that explains the low duv and higher CCT.
You’re not wrong. That is one way to do it… and it’s basically how the aux LEDs work. But as noted, the output is not constant; it varies with battery voltage. That’s not really an issue for aux LEDs, but it’s kind of a problem for the main LEDs.
I hope this image explains the idea, and why I want the 20mA channel to be regulated instead of just a resistor. It’s meant to smooth out the ramp between steps, but the ramp will only be smooth if the extra channel has a consistent slope.
Basically, the point is to make it look like the “4.0V” bottom center image… no matter what voltage the battery is.
It’s a different method than how FET+7135 or FET+5A works. With those, the lower power channel ramps up to full power and then stays on while the higher power channel ramps on top. But I’m thinking of doing a totally different method where the lowest power channel does miniature ramps between each step of the higher power channel.
I’m not sure if it’s a good idea, because it’s more difficult to do correctly… but it sure would be nice to have a truly smooth and stable ramp all the way down to firefly levels.
Also not sure if I should suggest it, because it means I’d have to rewrite a bunch of code. Would be nice once it’s done though.
Ok, I think I understand what you’re suggesting - the low channel tops out around the lowest stable level of the 5A channel.
I was thinking of using a 1x7135 channel full range, then either switching on the 5A channel in parallel as is done in 1+N x 7135 drivers. Alternately, if the different driver types don’t play well in parallel, then once the first channel reaches 350mA, the next step turns off the 7135 and turns on the 5A driver at the next logical step above 350mA.
But I hadn’t thought through what that would imply for the ramp resolution or scaling.
