The SD05 is a very small package with a high output. Build quality is very good, runtime is good, I don’t like the timed step-down very much despite the light having a temp sensor as well. Light color is on the cooler side of neutral white. Please enjoy my video review:
Overall I really like the light a lot and it is a great package for about 40 USD including battery and charger.
THX for your comments. This “hole” is part of the Traun river and the water is indeed cold but not as bad as some other rivers here in Austria. The area is beautiful and much larger than my video indicates. I only had a few minutes to do the video coming back from Salzburg. The light really would be perfect in warm white and without the timed step down. But it still is very good and the advantage of the timed step down plus tem sensor is that you can use it on land as well without concern about overheating.
Revisiting this message thread, will add my inputs for tailcap current measurements..
On the earlier SD05 (uses XHP50.2 6-volt) which uses constant-current (NoPWM on all modes), I got these tailcap current measurement:
L : 0.38A
M : 1.25A
H : 5.6A
Medium mode: changing from Low to Med or High to Med, gives same result for Medium level
(because on the newer SD05, Medium level is slightly different depending on how it was arrived at)
On newer SD05 (uses XHP50.2 3-volt), which uses fast PWM on the Low & Med levels, I got these measurement:
L : 0.6A
M : 2.2A
M*: 2.5A
H : 7.7A
all brightness levels are a bit brighter for the newer SD05 compared to the earlier SD05.
another weird thing is the Medium mode (notice there are 2 measurements):
If switch from Low to Medium, I got the lower Medium brightness setting (~2.2A)
but switch from High to Medium, the Medium level is slightly brighter (~2.5A)
this is a bit strange behavior someone reported in another thread, so I decided to also test my unit and got the above results.
I wanna get a SD05, take it out fishing and cast it out off a fishing rod in 100ft of water. See how that double Oring setup works under some pressure. I wonder what the ‘failure depth’ would be…30m…50m…100m??
