I received mine last week
First impressions: I like it !!
Second impressions: I like it, but…that High mode, on white room or with a “reflective” platform (including hands), gives me a headache!!
It thows quite well on High, and even if on Low it is brighter than I expected, I still think it does a good job keeping “night” vision.
BTW, the anodizing is slighlty different from the C01. It can be seen on the reflex!
Some photos below, just because!
(Click for bigger photos)
Absolutely. My goal is that they offer a (microlensed/frosted) TIR lens that can be used for both C01S and C01R, regardless what LED is "under the hood". So far, SST-20 and XP-E2 are very small 3535 LEDs. I hope that E21A's footprint will not exceed any limitations of the TIR's lower aperture.
Regarding your requests to lower the low mode. I gathered all your helpful suggestions and feedback and reported them back to Sofirn to improving C01R as well as to achieving the best parameters for C01S with E21A. I have no information how much C01R lights are left for sale and if Sofirn plans to release a second batch once the first one is sold out.
Honeycomb TIR C01R vs. standard optics C01S w/ Nichia 219*C*/4000K (I have no original C01S). AWB has obviously been adjusted to 4000K. Be aware C01S spot is significantly larger with the Nichia as opposed to the Luminus.
I swapped the optics in one of the recent C01S. Takes some force to overcome red threadlock, but works and left no marks on the body. But of course, it is certainly not for everyone. OTOH, it can be very frustrating to open the head by accident. That’s a strong argument for glueing it imo.
Had a little fun with a raw bead-blast C01S body and swapped the C01R light engine in. I think it actually looks pretty cool with the little red ring visible in the gap between the head and body. With a red tritium in the tail I actually think this would look pretty cool.
For those concerned with brightness on low, consider taking the head apart, and running this light as a mule. Without the optic, the floody red is much less intense on the two lower levels, and the extra bright high still manages to push out a lot of red. I will leave actual beamshots to someone with a DSLR. But here are some pictures I took with my phone for a rough comparison of what low looks like (in a lit room).
Stock TIR optic beam & beamshot:
Mule (no TIR/Optic) beam & beamshot:
Keep in mind for this to work you need to find a glass lens, or cut a small plastic disc out to fill the gap left between the head and pill, where the outer ring on the optic used to sit. without something there the head can screw down too far to have the light come on, and the LED is exposed. I made cut a small plastic disc out for my Mule C01S and have had zero issues.
Thank you and hope feedbacks and tips will be considered for improve both lights,would be great if you can advert us before the end of first batch,if there will be a second C01R batch
Should be noted that I am the only one who seems worried, and I don’t even have one in my hand yet. That said, too bright a low would invalidate pretty much every one of the “Typical applications” listed in the lead post.
I was given another suggestion:
Twist to OFF so that there’s about a quarter turn required to twist ON.
Press the head of the light like a ON button eight times and hold on the eighth press.
Each press should cause the light to switch ON. And it should power off and change modes when holding down for the eighth press.
It was attracted to one of the LED bulb ceiling lights in the living room. I opened a door to the backyard a few metres away from the wasp and switched on the external lights. I then walked across the room and switched off the living room lights.
The wasp stopped bumping into the LED light and everything went silent. I used the C01R to find my way back to the door. The wasp had dropped to the ground and was walking around near the door. After a few minutes it finally crossed the threshold of the door. I slammed the fly screen door shut…. and then I spent another 5 minutes waiting for it to make it’s way further into the backyard so that I could open the fly screen door and close the actual door.
My wife reminded me that insects are attracted to light and I should probably stop shining the red light at the wasp.
I just put some DC-Fix on mine and it is close enough. Smooth with plenty of spread. Low could be a little lower but I have no complaints. It will work nicely in preserving night vision with the telescope. Hi is very bright. Don’t see myself using it at all.
