thanks for posting your data captures (I summarized to show change in duv and R9):
still smells like a dogfart
From what I’ve found, the bug is only when the flashlight is in stepped mode. I don’t have this problem when in ramping.
Received the FC11 today. Battery is charging, so I am currently using a Samsung 35E protected button top to test out the light. Liking it a lot so far. The magnetic tail cap is pretty strong…
Here it is stuck to the Real Steel Flying Shark. I even moved the blade around a bit, but the FC11 held on.
So how’s the pwm for this light?
@Swabs:
Nice Firesticks!
(the succulent in your yard.)
Tendou - I don’t notice any PWM. I think the light is really good.
raccoon city - Thank you.
Thank you. I will get one then
This flashlight is pretty amazing for the price. I am very happy with it. But is there any special handling of the battery necessary?
This has been my EDC since I received it. It has a great (for me) UI, and a nice beam. Its easy to carry… it has never accidentally turned on in my pocket. The light is usable… good temp, no tint, high CRI. It has C-C charging that works. Its a really nice flashlight. My only wish is that the side switch was lit when the light is turned off.
Hi everyone! This is my first hi CRI flashlight and I really love it for a beautiful 4000k tint. I’ve got it also to have more sophisticated ui than standard commonly used ‘lo-med-hi’ in many cheap flashlights. I own it for like 4-5 months and have mainly positive emotions from usage.
However I’ve got some bugs that frustrating me a little:
1. Low voltage red light starts blinking at something like 3.9-3.8 Volts. It seems to me that this is clearly more than it should be. This problem occurs with any cell I have, even with standard Wurkkos 3000mAh 18650. This problem was from the very beginning and is not that awful.
2. Turned on flashlight sometimes won’t turn off untill you either change brightness or activate turbo or strobe. Especially if the flashlight was on for a longer than 5~10 minutes. This problem started to bother me about a month or so ago.
3. Memorized brightness level falls to eco after you turn flashlight in eco mode from off (with long press). Like if you turned off on middle level, then long press to eco, then turn off, then turn on again and ‘taa-daa’ you’re in eco again.This problem has appeared quite recently and is really disturbing.
I have to admit that it is a ‘new version’ of the fc-11 model.
If you have any ideas of how to make this bugs gone, it would be really nice!
However I believe that all these problems are refer to my own instance only and hopefully will not occur anymore else.
In any case I’m really thinking to get myself 2700k version though.
Cheers!
Whenever a light starts going mental, check allllll the retaining rings.
If one’s loose, tighten it. If they’re all tight, loosen them, jiggle the board to make sure it seats correctly, then retighten.
You have no idea how many mental lights were fixed by just doing that.
Thanks for the hint! The hack is that this flashlight hasn’t got any retaining rings inside. The driver as well as a bezel seems to be glued.
All I can do is to clean contacts.
The flashlight did not fall or sink, no dust inside, cell wrap isn’t damaged, nothing moves or dangles inside…
Never mind! That’s not that big problems for the 25 bucks light.
Looks like they just announced the FC12.
More lumens, and a tail switch.
Dan
I’m liking it already! Let me know if you hear more about it, I’m going to start searching.
Someone posted about it on reddit. Heres some details they mentioned:
- EDC Tactical 18650 Light
- Type C charging port
- Luminus SFT40 LED
- 345 Meters thrower
- 2000lm output max
- Power Indicator
- Length X diameter: 136.5mm*24mm
Got a few FC11s, I’d certainly grab a FC12
FC12 will release soon next Monday on our official website
The fc12 listing is active on the site, but I don’t see the color temperature specification or options to select a preferred tint. What is the CCT of this model?
There is an option for a black body or purple, which is cool. I’d like to see some pics of the purple body.
The SFT40 is only available in 6500K right now. I’d like to know more about the UI and the driver in the FC12 though.
These pictures of the purple prototype (among others) were posted on reddit recently: Imgur: The magic of the Internet
Currently no Eco/Moonlight mode for all FC11 sold by Wurkkos store due to problems
with electronic components. Confirmed by Wurkkos.
If you buy on Amazon or other stores you might have luck to get a no faulty one.
