Yesterday I did the dyeing, today I’m EDC-ing it but it is too heavy for everyday.
QSP Worker with carbon fiber/blue G10 laminate scales, RIT-died with “Racing Red” to turn the blue G10 into purple. I found the bright blue G10 too dominant, in purple it blends in more. And purple is my favorite colour
Is it possible to paint on Rit dye instead of dipping the scales in it? I was thinking of using frog tape, possibly cutting it into a pattern, tiger stripes or lines that get smaller as you go down the scale, just unsure if it would bleed past the tape or work at all once you dip brush in the hot mix…even a splotchy multicolor Jackson Pollock type application might be cool….er I have to many knifes that are black, one colorful wont kill me
There was never a Chill in a better steel afaik. I’d like one in Sandvik 14c28n for example, still budget but much better than 8Cr13/14MoV or D2, especially with Kershaw’s beloved bead blasting which even makes 8Cr rusty.
So no sprint run, just scales made by myself 4 1/2 years ago (as the timestamp says)
Excellent flipper on bronze washers, my slim Boker Urban Trapper would be more stable on bigger bronze washers as well.
Thank you. Well, I don’t know, especially due to the fact that the Boker UT hruns on ball bearings and would need some fitting washers to fill that gap first.
It doesn’t matter enough to me to search for bronze washers.
I’d look for them on ebay - phosphor(ous) bronze washers or at shops like usaknifemaker.com
As much as possible we should forget those guys that misused a Asian sign for the sun and prosperity and good luck.
+ a slew of other meanings depending on the cloture you focus in on, but those Germans once misusing it we should for get about, and only pull them out of the history books when someone need a scare.
Swabs , Chronovore: Thank you! I was having a hard time choosing between the full black washed and the dual tone version. Aesthetics won over practicality.
Fortunately this harlequin version solved my “which handle color should I go for?” problem.
