Review XTAR VC4S
19 posts / 0 new
roma58
roma58's picture
Review XTAR VC4S
Charger XTAR VC4S
The XTAR VC4S charger was sent to me directly from XTAR for review.
Immagine
For product features and technical data: www.xtar.cc/charger/vcseries/2019/0430/411.html
Main features of the XTAR VC4S:
• See clearly what is happening with the batteries
• Broadly compatible
• Quick charge QC3.0, Max 3A for each slot
• Try the actual battery capacity, maximize battery life
• Micro USB input, charge anywhere
• Intelligent detection to save time
• Automatically detects the type of battery
• Multiple protections guarantee safe charging
• High precision, auto-off when fully charged
• Activation "0V", restores excessively discharged batteries
Specifications:
Model: VC4S
Entry: QC3.0 (5V-3A / 9V-2A)
Constant current: 3Ax1 / 2Ax2 / 1Ax4 / 0.5Ax4
Automatic charge interruption (Voltage): 4.2 ± 0.05V / 1.45 ± 0.1V
Automatic charge interruption (Amperage): =120 mA
Use Temperature: 0-40 ° C
Dimensions: length 149 mm x width 115 mm x height 35 mm
Weight: 212 grams
Compatible with 3.6 V / 3.7 V Li-ion / IMR / INR / ICR batteries:
10440 14500 14650 16340 17335 17500 17670 18350 18490 18500 18650 18700 20700 21700 22650 25500 26650 32650.
1.2VNi-MH / Ni-CD: AAAA / AAA / AA / A / SC / C / D
Note: 20700/21700 protected batteries cannot be charged.
Immagine
Immagine
The Packaging:
The XTAR VC4S came in a white cardboard box. On the four sides of the box are highlighted, in 5 European languages, the main characteristics that distinguish the new XTAR VC4S charger.
The photo of the XTAR VC4S with the product name, connection type (USB), display (LCD) and supported battery type (Li-ion, Ni-MH) stands out earlier.
Later, other basic product features are listed.
Immagine
Immagine
On the two sides of the box we find other XTAR VC4S information such as battery compatibility.
Immagine
Once the box is open we find chargers and accessories in a foldable gray plastic bag (Hop-pocket), with the “XTAR” logo printed on it, useful for transport.
Inside are present:
- XTAR VC4S
- Micro USB cable
- Manual
Immagine
Immagine
The USB/Micro USB cable, present in the package, is 80 cm long and has the writing "XTAR" on the USB connector and the 2.5A writing on the MicroUSB one. The USB connector has the classic orange color that distinguishes compatibility with the QC3.0 fast charge protocol.
Immagine
Immagine
Immagine
The XTAR VC4S Charger:
After the release of the VC2S battery charger, the XTAR presents the version with four charging stations, namely the VC4S.
With the XTAR VC4S, we can charge batteries of various types and sizes such as Li-ion / IMR / INR / ICR (3.6V / 3.7V) and Ni-MH / Ni-CD (1.2V).
The XTAR VC4S supports the QC3.0 protocol and provides a maximum of 3A for each individual charging slot. It is equipped with a large color LCD screen that displays the charge status in real time and has protection against short circuit, overload and overheating. It is made of fire-resistant ABS material. It is also possible, with the VC4S, to reactivate excessively discharged low voltage batteries.
Below the display we find two keys, with a clearly audible click. The left button with the word "Disp." above is used for switching the display to: Capacity, Current and Internal resistance, while the right one with the word "Mode" above is used to choose the modes that are: Charging, Evaluation and Storing.
Immagine
Immagine
Laterally we find openings to dissipate the heat produced during the exercise.
Immagine
The sleight where the batteries to be recharged are placed, have a smooth run and the right resistance. The two side compartments (CH1 and CH4) can accommodate large batteries, such as the 32650 Li-ion batteries, with a diameter of up to 32 mm, while in the two central units (CH2 and CH3) I managed to get both a 21700 and a 18650 simultaneously. All the compartments are possible, as written in the specifications, also recharge 20700 or 21700 (but unprotected) batteries with lengths up to 70mm.
Immagine
Immagine
The XTAR VC4S charger is equipped with a Micro USB input (QC3.0), compatible with USB adapters, Power bank and Solar energy.
Immagine
Also in the rear part of the XTAR VC4S we find openings, on almost the entire width of the charger, which help to dispose of the heat thanks to 6 rubber feet that slightly raise the VC4S and give stability avoiding slipping.
The lower part shows the plate data and a white label with the XTAR identification data.
Immagine
Immagine
Operation:
The XTAR VC4S charger has three operating modes that can be selected with the right "Mode" button:
1 - Charging Mode. In this case it recognizes the type of battery and is adjusted by setting everything automatically.
2 - Evaluation Mode (Grading Mode) to have the effective capacity of the battery through a process of charging, discharging and recharging the battery.
3 - Storage Mode (Store) in case you need to store the battery at a nominal voltage (1.2V o 3.7V) to safeguard its duration if it is not used for a long period.
Let's see the behavior of the XTAR VC4S with the Charging Mode:
Once the USB/Micro USB cable is connected to a compatible power source (it can also be the classic cell phone power supply) and to the battery charger, the VC4S display turns on in stand-by, showing CH1, CH2 , CH3 and CH4 in green which correspond to the four available channels.
Meaning of the LED indicator colors:
Green: stand-by / fully charged / evaluation or storage process terminated.
Red: auto-exam / charge / activation.
Immagine
The display shows four circles, resembling clock dials, which show the battery voltage (0V to 4.2V - blue part) and the charging current (0.5A to 3.0A - in blue).
Above these circles we have a small blue writing that indicates, in charging mode, capacity (CAP), current (CUR) or internal resistance (IR), while below we have the indication of the charging mA and the type of battery chemistry ( Li-ion or Ni-ME).
When using the QC3.0 adapter, inserting a battery, if its internal resistance is low enough, the recharge will be at the maximum of 3A. If we charge two batteries at the same time then it will be 2A per battery. If the adapter does not support QC3.0 fast charge, the charging current will be 2Ax1 for single battery and 1Ax2 for two batteries.
Let's try to see what changes once a battery is inserted (in this case a 18650 Li-ion battery with adapter QC3.0).
The XTAR VC4S automatically recognizes the type of battery inserted and adjusts accordingly, in this case setting a maximum charge of 3A. We see that the light indicator of the channel used becomes red (CH4). Then we see on the display the indication, in real time, of the battery voltage and the set charging speed (3A), we then have the indication of the type of battery chemistry (Li-ion). With this charger it is not possible to manually set the charge speed (mAh).
Changing, with the "Disp." button, the information displayed, we read other data such as the mAh loaded and the internal resistance of the battery ().
Immagine
Immagine
Immagine
At the end of the charge the display shows the word FULL alternating with the charge current which results at 0 mA, moreover the luminous indicator of the channel (CH4) becomes green.
Immagine
Immagine
We see the indications on the display by inserting a battery of different chemistry, in this case a 1.2V Ni-MH AA.
In this case we have a variation of the scale on the circular indication which will now be from 0V to 1.55V, and the word Ni-MH which identifies the chemistry of the battery. I'm doing other tests, but it happens that if I charge low resistance AA batteries the charger sets the charge at 2A.
I just hope it's an error on the display but it's not real.
Immagine
Immagine
Immagine
Finally we see the initial indications of the XTAR VC4S display when we are in Evaluation Mode (Grading Mode) and at the end when the display flashes showing the word "donE" and the battery capacity found.
Immagine
Immagine
Immagine
Immagine
...... and in Storage Mode (Store).
Immagine
Immagine
The XTAR VC4S with the four slots occupied by four different sized batteries:
from left: 16340, AA, 18650 and 21700 (unprotected).
Immagine
Conclusions:
Good performance of the XTAR VC4S charger, simple to use, versatile and fast. With this charger we can recharge a cell quickly to a maximum of 3A thanks to the compatibility with the Quick Charge 3.0 protocol. Too bad there is no possibility to choose the charging speed in case you prefer to manually set the mAh to be charged. From the tests made in these days I have found that the speed regulation depends in particular on the internal resistance of the battery.
In addition to the standard recharge, we also have the possibility of evaluating and storing the battery obtaining information on the actual capacity of the battery and bringing it to a nominal voltage, for its protection, in case it is not used for a long period or for safety in transport case.
The XTAR VC4S also has the 0V activation function to restore excessively discharged batteries.
In conclusion, a charger with multiple functions recommended, in particular, for those who need a fast tool with automatic settings.
Thank you for reading the review.
Immagine
Edited by: roma58 on 05/24/2019 - 12:11
M3CSL
M3CSL's picture
Last seen: 2 years 2 weeks ago
thanks for the review. I had the VC4 last year, sold it because it was too slow.
This one looks good.
Convoy S2+ 219b triple, Astrolux FT02, Maglite 3D, Solarforce L2t
Mishanchik
Mishanchik's picture
1. Do I understand correctly that VC4S will charge AAA LSD Ni-Mh with a low internal resistance, a current of 2A, actually killing a cell?
2. What can you say about the accuracy of the measurement of internal resistance on the basis of this link?
https://www.facebook.com/ShenzhenXTAR/videos/384125089087079/
3. What is the voltage after removing the cell from the charger for lithium and nickel in each of the 4 slots?
4. What is the exact length of the slot for the cell, not according to the manual, but measured?
roma58
roma58's picture
Mishanchik wrote:
1. Do I understand correctly that VC4S will charge AAA LSD Ni-Mh with a low internal resistance, a current of 2A, actually killing a cell? 2. What can you say about the accuracy of the measurement of internal resistance on the basis of this link? https://www.facebook.com/ShenzhenXTAR/videos/384125089087079/ 3. What is the voltage after removing the cell from the charger for lithium and nickel in each of the 4 slots? 4. What is the exact length of the slot for the cell, not according to the manual, but measured?
1 – I’m doing other tests, but it happens that if I charge low resistance AA batteries the charger sets the charge at 2A.
I just hope it’s an error on the display but it’s not real.
2 – I have no professional tools to do tests on internal resistance.
3 – From what I’ve tried (measured with a multimeter) I got 4.18V with Lithium and 1.51V with Ni-ME (AA).
4 – The maximum length available is 70mm measured.
WalkIntoTheLight
Last seen: 7 months 1 week ago
If it’s like their X4 charger, then yes, it uses 2 amps on AAA Eneloops. While that won’t “kill” the cell, it’s certainly not good for it, and it does get quite hot while charging. AA cells also charge at 2 amps, but that’s okay for them, even if it’s a bit faster than I prefer.
IMO, I wish they picked 0.5 amps for AAA, and 1 amps for AA. They could limit it by cell length, like a lot of other chargers do.
Mishanchik
1. My Xtar VC2S charge AAA cells with low internal resistance with current 2A… It seems that in the VC4S, the Ni-Mh charging algorithm has not changed. But if you look at these devices:
https://lygte-info.dk/review/Review%20Charger%20Varta%20LCD%20Ultra%20Fa... with current 8A :))))
or https://lygte-info.dk/review/Review%20Charger%20Duracell%2015min%20CEF15... with current 6A :)))
Against the background of these two chargers, Xtar charges look very tender LOL
2. It’s a pity
3. Its very good. because my Xtar VC2S charge Ni-Mh up to 1.38 in 1 slot and up to 1.44 in 2 slot.
4. I really hoped for 75mm …
roma58
roma58's picture
2. It’s a pity
Regarding point 3 I came to have 1.51V only with a battery, with others the final volts have always been different. I’ve tried so many and unfortunately can’t remember what it was.
hank
hank's picture
Last seen: 2 hours 23 min ago
Quote:
if I charge low resistance AA batteries the charger sets the charge at 2A. I just hope it’s an error on the display but it’s not real.
That’s a fatal flaw for me. Overpowering small batterie is unacceptable. Give me manual control, not a stupid automatic power setting.
You say the charger can work on solar power. Is that just what they say, or were you able to verify by using a solar charger?
You probably know the usual problem is that a cloud or shade lowers the voltage from the solar panel, and the device resets itself (or fails to reset itself).
What happens when you test it?
WalkIntoTheLight
That’s what I like, too. However, I think Xtar designs “plug and play” chargers, where any user can just stick in a cell and let it charge. No buttons to push, or anything to choose.
I think that’s a good approach for a family charger, but not for batteryaholics.
What I don’t understand, is why Xtar is so wrong about AAA NiMH charging. In my experience, they do choose good charging currents for 14500 cells, at 0.5 amps. So they are using the internal resistance to set the charging current, but it appears only for lithium-ion.
For NiMH cells, they always seem to max out at 2 amps, regardless of the cell size or age or internal resistance. I don’t think they’re measuring the internal resistance of NiMH properly, which is why they always use max charge on them.
Mishanchik
Batteryaholics must buy MC3000 – they have no choice LOL
By the way, I do not like MS3000 – but it can not be called intelligent charger. Correctly call it a programmable charger. It does not make decisions on how to charge the cell, for example, Xtar VC2S, VC4S, all MiBoxers – charge the cell based on the measured internal resistance of the cell.
marcolopes
Well, this charger will many times select 3 amps for cells that should not even be charged at 1!!! This is totally nuts!!! I was watching this review and confirmed exactly the same… https://youtu.be/wPF9LoOvYY0?t=415
What the hell was XTAR thinking? Even if there was manual selection, it would be a bad thing, imagine it without any manual control! This was supposed to the the next step over the VC4 version…
richbuff
Last seen: 2 min 44 sec ago
The only way I can get enough amps into the cells when I am charging four cells is by plugging my VC4S into a very high amp wall adapter. The only way I can make sure I’m not frying my battery when I’m charging only one small cell is by plugging the charger into a very low amp wall adapter.
Rev 22:15
marcolopes
Well, that’s a “workaround”… sincerely, i’m tired of “workarounds” with electronic equipment (been doing that for most of my life!). It’s time consuming, prone to errors, and eventually something will end bad. This is a pure design flaw that can result in serious damage of the cells and/or charger…
richbuff
Points taken.
VC4S is not long enough for protected 21700, so I ordered two VC8 a few days ago, they are on their way. Apparently, the VC8 is kind of like two 8-bay chargers sharing the same body. Bays 1-4 and bays 5-8 have differing operating features, so I can manually set the amps when charging a single protected 21700.
Rev 22:15
river345
I’m also concerned about the high charge current for NiMh cells. I’m still pretty new to 18650 cell, so pardon the newbie questions. Is there a problem charging 18650’s at lower currents (like .2amps or .5 amps) other than it would take a long time to charge? Is it like NiMh cells, in that it prolongs the life of the battery? Is using a lower capacity USB charger pretty reliable if you don’t care about charging speed but don’t want to hurt your batteries?
In storage mode, am I reading that right that it discharges the 18650 battery? Doesn’t that reduce the life-time recharge cycles? How often does it charge/recharge in storage mode?
I also wonder how fast it discharges batteries in evaluation mode. I would not want high current discharge.
d_t_a
Last seen: 1 day 17 hours ago
Xtar VC4S ‘grading’ (capacity test) mode uses a slow 300mA (0.3A) discharge current.
Most chargers cannot discharge at high current (charger will get hot while doing discharge testing), I often see 500mA with only a few that can do discharge test at 1A. Very few can discharge more than 1A (e.g. SkyRC MC3000 can do discharge test @ 2A discharge current, but if only 1 slot is used)
I’ve also wondered whether putting batteries in storage voltage (around 3.7v) vs the additional charge/recharge cycles when battery is placed in storage voltage — my guess is that it depends on how long is the ‘storage’ going to be, and also (based on what I read) what level the battery is charged. I suppose keeping batteries for say more than 3 or 6 months, then putting in storage voltage will help, compared to having the battery sit idly at fully-charged state. However, from what I read, the strain will also be less if the battery is not charged to full 4.20v (eg. just 4.05v) would make the battery still usable for emergency purposes, and while 4.05v is still higher than “storage voltage”, it’s not as stressful as 4.20v. (I’m mentioning these based from some readings on the Internet)..
Regarding charging at slow 0.2A or 0.5A. I would consider 0.5A as still acceptable. But 0.2A, while charging is not stressful to the battery, I think it increases the time the battery gets to full (ie. the battery will stay at the “nearly full” level for a longer period of time). From what I understand, a battery kept at “full” is generally considered as “stressful” for the battery. (much like having a smartphone charged overnight, this probably doesn’t “over-charge” the battery — but it keeps the battery at 100% charge, which can add to the stress of lithium-ion battery).
kalanh
What wall charger do you use to power this and other QC3 charger devices like the Xtar VC8 (that I own). I cannot seem to get a single type-C charger to work with a straight type-c cable. What does work is type-c to female usb a, then usb a to type-c, weird… but it works. From what I’ve read QC3 on type-c cannot be properly certified due to the way the power is configured and can’t be up to USB’s (governing body) standard.
ArtieT59
ArtieT59's picture
Last seen: 1 hour 16 min ago
Best day in my flashlight hobby - last March I ordered a Vc4 from neals gadgets on sale for $17.99, and for whatever reason I got a vc4s in the mail. At the time I didn't know the significance of that, but now I do. Love this charger! Use it everyday for the last year+
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
ChrisGarrett
ChrisGarrett's picture
Last seen: 6 hours 13 min ago
Hard pass for me and I have ~15 Xtar chargers, including the VC4/VC2 special jobbie.
Chris
