According to LTK FreeTiger uses real D2 steel with very good HRC so it’s unlikely that they use fake 14C28N. According to another youtuber’s cutting and sharpness testing of D2 and 14C28N from TwoSun, 14C28N outperforms D2 by edge retention. So I hope FreeTiger’s 14C28N won’t disappoint me either.
From what I read 14C28N is more adapted for a kitchen knife and D2 is better for a outdoor knife. So yes 14C28N would be better for EDC. I think the only notable difference in use would be the rust spots on the D2.
Did you noticed they also started to use S35VN? https://www.srmknives.com/product/1161-tz/
On knives for food prep I’d prefer 14C28N over D2, due to rust resistance and still a good edge.
On my GreenThorn work edc I’m quite happy with its D2 blade. It’s getting wickedly sharp and holds a good edge.
I get no rust spots because I sometimes rub it with mineral oil and use it every day but even if I had some spots on it I wouldn’t mind.
I’d maybe just polish the blade or stonewash it, really doesn’t matter.
Anyways, here’s my new SRM 9306. Very nice slim knife for $20. Do I like 8Cr13MoV?
Haven’t tried edge retention on this one so I can’t say but it’s a light duty folder so I don’t mind.
The thing is, I want to gift it to a friend who destroys every knife within some months anyways, the most important part will be the bottle opener I guess.
And the blade will have greenish-brown residue on a blunt tip on it but by then it won’t be my knife anymore, nothing to bother about
Size comparison with the Boker Urban Trapper (01BO732)
I don’t know if it will be ever possible to open this knife comfortably with the thumb studs but oiling the tang and opening/closing it a few times helped already.
The closing torque point is a bit smoother than the opening one, so it’s a bit difficult to overcome the last few degrees while opening it onehandedly, with two hands it’s working very well, even without nail nicks, and it also hold the blade open with enough force.
I received my knife in the mail today and am less than thrilled by it. The size is compact (which is fine), it’s a comfortable knife that fills the hand well, but the button is very firm to actuate and it doesn’t always open completely and lock. The spine section that locks onto the stud and notch in the back of the blade is very rough and gritty and the blade gets hung up. I’d pass if you are thinking of ordering one. I’ll see what I can do to slip some high grit (1000, 1500, 2000) under this area in an attempt to smooth it out. I did lubricate it but that didn’t change the action. Oh well. You take your chances… I don’t know what I’ll do about alerting Aliexpress. I don’t expect any real satisfaction from halfway around the world.
Not really. Sandvik developed 14C28N at the request of Kershaw for use in pocket knives. It’s an improvement on their older 13C26. The main goal was to make it more resistant to corrosion. They succeeded.
I prefer 14C28N to Chinese D2 any day of the week and for any task. The D2 can have better edge retention depending on the individual heat treatment. The problem is that it can be a gamble. The average edge retention for Chinese D2 is a slam dunk over 8Cr13Mov and lower-numbered steels in that series. However, that average isn’t enough better than 14C28N that I care. Given the big and reliable difference in corrosion resistance, 14C28N has the advantage for both EDC and outdoor activities.
Well you just had to go and show me that didn’t ya. I have been really good. Haven’t ordered a new knife in a while. Then you show up with that beautiful thing and now I got the itch again. It also didn’t help that I found this while looking for a TS164. Hadn’t seen that one before. I’m gonna get in a lot of trouble.
Eafengrow EF04. My first Eafengrow, and not a good first impression.
The blade is way off to one side. The gold stripe pattern is poorly done at the base of the blade. In order to get the blade centered, the pivot screw has to be tightened to the point the pivot action is too stiff. Opening the knife is not good, and it won’t close unless you force it closed. I’m going to return it.
If you like that design, the Ontario Rat might satisfy ya. Aus-8 or D2 in all kinds of handle/blade options. Aus-8 for about $25 or so, $40 for the D2. They are all over Amazon and Ebay. Might get them cheaper from overseas but then you get the long wait on shipping.
I do have a RAT 1 with AUS8 and I am impressed with how well made, and how wonderful it feels in hand. I didn’t get the good steel (D2), and it has FRN scales, but it is a great knife none-the-less. When I seen the Eafengrow EF04 I wanted to see how it would compare, but I have no love for the EF04. It is almost as bad as the junk Canku C06 knife I bought not to long ago, and immediately returned it.
I don’t have any Eafengrow or Canku knives but, I can certainly understand being disappointed in a knife I looked forward to getting. The Ruike P831 I got was horrible. Blade way off center, the frame locked pushed so hard against the blade it was impossible to close or open one handed. Worked on that knife forever trying to get it to work properly. I gave up and gave it away. He is a friend too. I should have never done that to a friend.
Just received my first Stedemon knife. The price on Amazon showed it was $22.29 for the orange one, but it came out to $19.39 with tax included at checkout. That was a nice surprise! Would make a good budget gift.
I like the knife. It is good for the price. A 3.3” 440C very sharp blade, and good quality plastic (FRN ?) scales. Feels good in hand, like a quality budget knife. Has a good strong lockup. The blade can be deployed by a quick shake of the knife. The detent is on the weaker side, that’s my only con on it.
Just be careful. There is elastic deformation, inelastic deformation, and straight up snapping. Some liner steels are more forgiving than others. You also want to apply pressure evenly so the lock bar continues to mate up properly with the blade.
I’ll only try this on inexpensive knives. If it’s an expensive knife, I’ll either return it or send it in for warranty work.
