OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
I ordered from here last week but until they arrive I will remain skeptical
We have waited two years for this LED to finally become available! Supposedly the ultimate thrower LED.
Interestingly, the SBT-90.2 which became available in the meantime is a better fit for many larger lights.
:partying_face: I hope it will not be to hungry…
That “HX” from AE (YinDing) seems off. What’s with the exposed gray portion next to the die? Also, their other white flat listings have unusual markings on the surrounding white areas of the package.
I’m using their red flats and they’re legit
I would guess preliminary version of LED (is why it looks different)
I got here 2 flashlights with supposedly Osram NM1 LEDs
Both have some letter markings on top of the LED, but one of them also has a grey bar on the side (while the other does not).
Is there any difference?
Why do you think they call it LED lottery? You are supposed to scratch it off and see if you win!
/s
no idea
As contactr mentioned earlier. I’m presuming this is a pre-production or engineering sample type marking…
Another 2 flashlights with Osram, one has the gray bar, the other doesn’t.
Any specs?
The right one seems to be the CULPM1;which is the higher current version of CSLPM1.TG. There aren’t too many manufacturers around which use them
They look the same size to me. isn’t the CULPM1 the 2mm version?
Both flashlights are the same model: Manta Ray S21 with Osram NM1 LED (supposedly) - one has a gray bar, the other does not. The Manta Ray S21 uses a 2.8Amp (7135x8) driver, but the UI is sort of different (it seems to be related in terms of configuration as the Convoy C8+ SST40 ‘ramping’ driver version).
In my other set of Osram NM1 photos, one is a Wainlight C8S-G with Osram NM1 LED (no gray bar), the other is a Boruit C8 with Osram NM1 LED (but has a gray bar). The Boruit C8 and the Wainlight C8S-G look very similar (they use the same flashlight host as the Convoy C8+, but place an Osram NM1 LED and both seem to use a driver that is similar to Convoy’s 5/3-mode group driver (also 7135x8 or 2.8Amps).
you’re correct
i was thinking about this one
Wow that’s a good find! You can even buy this soldered onto various size boards down to 11.8mm for use in AAA sized lights!
CULPM1 also has a 4x4mm pad IIRC (vs 3x3mm on the CS models), isn’t that why it has higher thermal resistance?
Yes, but not on 3030, he uses 3535 and the copper boards aren’t dtp
BurningPlayd0h, according to my wisdom a bigger footprint equals lower thermal resistance; or it should.
Kaidomain has both 3030 and 4040 DTP boards for sale, check here:
http://kaidomain.com/Flashlight-DIY-and-Tools/led-pcbs-or-mcpcbs?limit=100
In the absence of led4power (hope they're back sometime), some way or the other we now have access to all 4 White Flats. The thread should now be renamed to
OSRAM CSLNM1.TG 1mm², CSLPM1.TG 2mm², CULNM1.TG 1mm², CULPM1.TG 2mm²
or maybe to
Hope Mr luminarium iaculator notices. Is someone going to test the Boost HX? The 2mm² WF is more surface to power constrained, this means the Boost HX should obtain a higher gain than the HL. Sent a PM to djozz…
I did seen and changed… :+1:
I still can’t remember those Osram emitters… It is to complicated to me. Letter and number dizziness :weary:
P.S.
First post of this thread requires re-editing with all relevant data. Thread is hard to follow and maybe it is better to read it backward > forward direction.
