[Review] Convoy M21C ( XHP70.2, 1 x 21700) - Excellent performance and regulation # Outdoor beamshots included
[quote=Swabs]
Thank you for your feedback.
Yesterday i got mine. I gotta say that SMO reflector shows amazingly small amount of yellow crap comming from XHP70.2. I’m still surprised. And those rings Swabs are talking about are coming from the bottom part of the bezel ring and sometimes from reflector emitter opening.
Simple solution is to use permanent marker and ink just the opening of reflector and bottom part of the bezel ring. Be carefull not to touch the inside of reflector!
Beam gets improved instantly without rings. I’m gonna heat anodize bezel ring for much better look instead of just painting it.
Truely impressed with SMO reflector!
I just got mine and it has the same ring around the edge. Does not bother me. Nice light. Great price. I like Convoy a lot.
Received my M21C, excellent flashlight, the only thing that does not fit me on paper and that my M21C differs from the measurements of the review are the lumens and the consumptions. The normal for 4,000 OTF lumens is about 15A, and that proportion I get in mine, about 8.5A and 2,700 lumens, very far from the 9A and 4,000 lumens of the review, but still excellent.
I also measured the M21C XHP70.2 at around 8-9 Amps max (tailcap current), which is also similar for the Astrolux FT02S (XHP70.2). Both flashlights claim “4000+” lumens, but my own “guesstimate” (ceiling bounce lux measurement) would be in the ballpark of ~3000 lumens, which matches with the power/current consumption.
I would say the Convoy M21C (XHP70.2) and the Astrolux FT02 (XHP70.2) are very similar in terms of brightness and beam pattern. Both have similar size heads and both use 1x21700 battery. Difference is one uses a tailswitch and the other uses a side-switch…
Anyone tried the new Orange Peel reflector with XHP 70 ?
No one mentioned compatibility with 18650. Is that a non-issue?
I have it. Like it more than SMO cause beam is just perfect. Transition from hotspot to spill is flawless but throw is a bit reduced.
OP makes the light more floody,
IMR18650 can be used in M21C
Thank you Simon,
that means no Samsung INR batteries including 30Q,
only something like Efest IMR, 20A 35A ?
No, he just means 18650s will fit in the light and that high drain is suggested/required. 30Q should be perfectly fine since they can handle 15A (and even 20A, but with significant voltage sag).
In fact, INR batteries can also be used
That’s great, makes sense, I think originally, I got confused by
Other 21700 flashlights list
What XHP 70.2 color temperature do you guys recommend?
  1. XHP70.2 6500K
  2. XHP70.2 5000K
  3. XHP70.2 4000K
  4. XHP70.2 3000K
M21C will be used as a thrower and I am ordering one with SMO reflector for max throw. ’
But I am not sure if I should get 5000K or 4000K.
Is the 4000K less efficient in terms of kcd and throw?
i dont think XHP70.2 LED is a good selection for long range light
Sample beamshots of the Convoy M3 (XHP70.2) at close range (around 18 meters or 60 feet from the wall ahead)
(these are the Convoy M3 XHP70.2 6500k, XHP70.2 5000k and XHP70.2 4000k)
another set of 3 Convoy M3 -- these are the Convoy M3 XHP70.2 5000k, XHP70.2 4000k and XHP70.2 3000k)
The Convoy M21C has a bit larger head than the M3, so should throw a bit farther than the M3 though.
Here I have some 3 beamshots of the Convoy L6, which has XHP70.2 6500k, XHP70.2 5000k, and XHP70.2 3000k.
(distance of flashlight to opposite building around 150 meters or 400 feet)
Convoy L6 XHP70.2 (P2-1A) 6500k beamshot:
Convoy L6 XHP70.2 (P2-3C) 5000k beamshot:
Convoy L6 XHP70.2 (N4-7A) 3000k beamshot:
(Convoy L6 also has XHP70.2 4000k, but I haven't tried that, so no beamshot).
The Convoy L6 has slightly bigger head than M21C, so it throws a bit farther than the M21C.
Very nice beamshots. Thank you that was very informative. The L6 is really nice.
Now I understand why so many requested the OP reflector for the XHP70?
What LED would you recommend?.
I think the SST heats up much faster than the XHP70, so I assumed the XHP70 will throw and lasts longer. But I could be wrong.
m3 or m26C xhp70 3000K for more flood with op? thank you!!
Thank you for these tips. Could you possibly show pictures of exactly what part of the bezel/reflector opening you are speaking of here? I am not 100% sure what side of the reflector (top or bottom) you are suggesting to use permanent marker on… Sorry im new, and not too bright. Thank you, of you arent able to, no worries. i will do more research. Thanks again
I’ll post it tomorrow.
Emitter opening, part that seats on top of the LED (more on plastic centering ring).
