Lumintop Tool AA 2.0 flashlight
40 posts / 0 new
BOO5TED
BOO5TED's picture
Last seen: 8 hours 34 min ago
If you can take the tail switch apart, you can remove the leds imo.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
jon_slider
jon_slider's picture
Last seen: 8 hours 52 min ago
more AA Tool on 14500, LED tail discussion here:
gchart wrote:
Yes, removing either the LEDs, the resistors, or all of them (should be two of each) would remove the drain.
I swapped mine for a custom LED tailcap and am only getting 0.08 mA drain, which on a 900mAh battery translates to 15+ months of standby… much more acceptable.
moderator007
moderator007's picture
Last seen: 2 weeks 2 days ago
When the light is turned on the driver is running with the firmware, checking for LVP. When you turn it off, the driver is off (switch breaks connection) and not checking a thing. The lighted tail switch is working in backwards polarity compared to the driver. No power to driver, lighted tailcap power is on and no LVP. The lighted tailcap will drain your battery dry while the driver is sleeping Big Smile .
Yokiamy
Yokiamy's picture
Last seen: 4 hours 54 min ago
jon_slider wrote:
Yokiamy wrote:
It has LVP set at 3V
Yokiamy, can you please share the source of your information? because I dont know who to believe:
bilakos10 wrote:
Nev wrote:
Just be aware that it doesn’t have LVP , I always use protected cells in the tool AA , I once ran down a 14500 to under 2 volts.
Indeed there is no LVP. To my knowledge, it quite a common practice on flashlights that use a boost/fet driver and accept both NiMH and LiION cells.
My own
I only have three, a Ti, an upgraded Ti and a Cu.
jon_slider
thanks for the info Yokiamy
I see moderator007 also says there is LVP on LiIon..
is this a complete Low Voltage Shutoff at 3v?
or just a Low Voltage Warning that only blinks or somesuch, and then continues to drain..?
moderator007
I haven’t checked mine to be sure, but I assume if the light is on and hits the low voltage to trip LVP the driver goes to sleep or continues to check voltage to know when to wake back up. Either one I would think would be a very low power consumption. After LVP kicks and you turn the light off then the vampire lighted tail cap would kick in again.
To solve this defect, you would either need to change the lighted tail pcb out for something like gchart has done or change the current limiting resistors out to a higher value (something up in the 100k range) but the tail cap will be pretty dim then and only be seen when its dark (switch boot is not very transparent). Then there’s always the option of just removing any of the components that make up the lighted tail cap pcb (leds or resistors) but then you have no lighted tail cap.
Maybe Yokiamy can answer the question on weither it blinks or shuts off with LVP. Thumbs Up
jon_slider
I was impressed at the level of detail in your comments about the tail vampire.. I gave the CuTool AA to a good friend, that only speaks Alkaleak.. so no concern over the tail LEDs
but yes, on LiIon, the lighted tail would be a non starter in stock form.. I agree an interventioni would be required to drive a stake through the vampires heart.. LOL
Yokiamy
Yokiamy's picture
It looks like it completely shuts off
jon_slider
thanks, looks useful
plenty of warnings that its time to change cells
with dimming before sudden darkness
