The more I think about it the more I like the idea of the clip being built into the tail cap. Similar to this but deep carry.
This would make it a simple tail-cap replacement option. Similar to benchmade knife clips it could be screwed on or it could just be permanently fixed and you change the tail-cap to add/remove the clip…
I’ll worry about the clip once my KR4 gets to Canada, been having a blast with the KR1 no issues with the clip for me…… Though then again I’m pretty sure the ship that my package is on is lost at sea along with its crew maybe taken by pirates…… 128 days and counting hope is fleeting….
All the orders stuck at this status before have all been delivered at the end of July.
“2020-05-10 16:05:00 CAYVR / Despatched to overseas”
But those packages below are still stuck there, I can’t tell when they will move,
but as far as I can tell they will move at any time of this month
“2020-05-22 16:08 CAYVR / Despatched to overseas”
And they are the only packages to Canada which are still stuck on the way, I’m sorry for the inconvenience.
For example, this is one of the package stuck at 2020-5-10, there is no movement from 2020-5-10 to 2020-7-24
2020-07-29 16:31:00
/ Item delivered
2020-07-29 11:17:00/ Send item out for physical delivery
2020-07-29 06:42:00/ Receive item at delivery office
2020-07-28 18:43:00/ Receive item at sorting centre
2020-07-27 01:00:00/ Receive item at sorting centre
2020-07-26 17:14:00/ Transit to Destination Processing Facility
2020-07-25 05:01:00/ Held by Customs at Destination
2020-07-25 05:01:00/ Arrival at Processing Center
2020-07-24 23:25:00/ Arrival at Destination
2020-05-10 16:05:00CAYVR / Despatched to overseas
2020-03-31 23:30:59HK / Hand over to airline.
2020-03-31 14:54:00/ Information Received
2020-03-31 14:18:37Domestic Air Cargo Termina,Shenzhen,China / Depart from facility to service provider.
2020-03-28 19:07:05Hongqiao,Shanghai,China / 4PX picked up shipment.
2020-03-28 19:07:05
Hongqiao,Shanghai,China / Shipment arrived at facility and measured.
It looks like E21A 2200K is no longer an option on the website. It had a good tint below BBL, I hope it will be back or (even better) be replaced with E21A 2000K.
I received a KR4 Ti today.
Everything appears to function as it should except thermal stepdown.
Once the light gets hot it does not step down, instead the light shuts off completely, including the AUX LEDs.
It feels like the outside of the light reaches around 65°C - 75°C.
When the light has cooled down a little after a minute or so it comes back to life, the AUX LEDs come back on and the light can be operated normally until it heats up again then it shuts off.
I have tried resetting the light and thermally calibrating but it is still the same problem.
It looks like the thermal stepdown is not working properly and so the driver is heating up then triggering a thermal protection in the driver, if it has such a safeguard?
My normal questions don’t apply, since you’re you and you know better. However, could you post the firmware version? My understanding is a 15-click from off should blink it out in YYYY-MM-DD format (though I don’t own anything with a new enough version to do this).
It sounds like the sensor may need to be calibrated. Have you tried doing a factory reset with the light at room temperature?
It also sounds like the battery might be getting overloaded and shutting down until it cools off. Something is causing it to disconnect power, wait, then reconnect power.
I don’t know for sure that’s what is happening, but the issues described could be caused by bad calibration and a cell which isn’t strong enough to sustain full power. Recalibrating it could probably fix one issue and avoid the other.
Interesting. I have recalibrated it at RT and also factory resetting.
Tried 30°C room temp calibration setting with 40°C limit, light still gets roasting hot & shuts off.
Cells I have used are brand new Shockli 1100 mAh 18350, Vapcell 1100mAh 18350, Sanyo GA 18650 and 30Q. The GA is new, 30Q quite old.
I did consider it may be the cells but doubt it with the same behaviour with all even at only 5A current draw.
