You know, it might help for lumintop in the future to work with T/A a lot closer and have him informed. A lot of us trust on T/A’s experience and knowledge and will depend on that to sometimes buy products from these companies. Especially on something like this, since for the most part I believe that people from this forum will be the main buyers. I don’t know why they leave you (T/A) out of the changes. My .02 cents.
To play devils advocate: Lumintop is not in business to make the best flashlight ever, they are in the business of making money. There is a point at which changes and improvements cost them money instead of making them money, and they have to try and decide that point to bring the light to market.
(that said, I agree with the sentiment that TA’s advice should be followed whenever possible :+1: )
But it is not uncommon that if at a prototype stage they discover how good a flashlight is that is proposed, they turn enthousiastic. If that point is reached, there is more than just making money, they may go for a good product too. Chinese flashoholics are only human too
Btw TA,in thread title: passive looks better with double s
Yep, which is why it is odd they don’t just talk to me. I am quite good at balancing costs vs performance and finding the best trade offs if they would include me in the loop. I am always looking for the best bang for the buck option.
A lot of times I will toss out a few options for them to compare / price check expecting a response on what they feel the most cost effective option would be so I can work from there but have just simply not gotten a reply in most cases recently. Not sure why, I think it is at least somewhat due to the language barrier.
I think they take me suggesting something or asking for costs on a particular option as me saying it needs to be this way vs the reality of me simply wanting to know if change X would cost an extra 5% but gain %20 in performance.
I wonder why they’d drop the smo for the OP reflector? I don’t think there’s much difference in cost (I know reflectors are pretty expensive when they get bigger) between them? As far as performance, the OP will make the hotspot less intense and reduce throw (wonder how much), but help with the corona and tint shift of the 70.2.
My guess is to help with the tint shift and clover leaf beam pattern. I don’t think the throw will be effected that much, it is generally a lot less then most people think.
I’m wondering what options we have for batteries? I’ve not measured current yet, but I’m assuming around 40 amps out the gate and 30+ most of the cycle. Since we must have button tops, I can find much. I’m running VTC6s which perform very well but max continuous is 15 amp with 30 amp at 80 C temp cutoff.
The closest thing I have found in a button top is the VTC5A 2600ma which is 25A maximum continuous, 35A maximum continuous with an 80deg C cutoff.
If you guys know of anything else available that would be as good or better please let me know……
Got to also keep in mind that lower drain cells will also have higher resistance and thus will not draw as much current to start with. Have you measured the current? Or just guessing? Think I was seeing a around 30A (still over 400W) in my early prototype but the improvements I suggested should of raised that a little.
On my early prototype I tested it with 30Q cells till the cells were dead and when I pulled the cells out they were still under the rated temperature (forgot exact number). If they can handle it, most high drain cells should be able to unless they really improved the current draw in the final light.
Most people are also only going to run it for short bursts as well with the thermal step down in place. The only time the cells needing to handle the full current is a real concern are those that disable the thermal stepdown and plan to run it for extended periods. These are the people that should know enough to plan for that.
